    Feb 2010
    England
    I have an MKV file that has a single audio stream, Dolby TrueHD. This does not play any audio when I play the file through my WD TV Live, so I am looking for some software to extract the audio stream so that I can convert it to AC3 and add it back in.
    I have tried mkvtoolnix and eac3to, but neither are able to extract the stream.
    TIA
    Have you tried popcorn mkv audio converter?
    Feb 2010
    England
    I've not tried that.. I'll fire it up now and have a look, thanks..
    EDIT: Bah, it all looked so good until I hit the run button..
    Unsupported Audio codec: A_TRUEHD.
    Jun 2004
    California,United States
    Something that I noticed is that Makemkv will do that automatically if you select the DD button only and not the Truhd button.
    Or at least it seems to. When I put the resulting MKV file in MediaInfo after I do that it just shows a 640kbs AC3 file as the audio.
    Tony
    Feb 2010
    England
    Thanks, but I already have the MKV with TrueHD audio. I am looking for a method of extracting the TrueHD stream so that I can convert it to AC3 and reinsert it into the MKV..
  6. (never mind. posted it in another similar thread)
