Hi,
i have looked everywhere on the forums and i have not come accross to a solution to my problem. im trying to capture video from my xbox and watch what im doing on the tv at the same time.
here is my set up:
XBOX connected to Intensity Pro Thru HDMI cable in the Input slot.
Then i have an HDMI to COMPONENT cable connected to my TV.
Long story short, i can capture video on my PC as normal, but i cant get my
TV to show an image. its a black screen.
There's no such thing as an HDMI to component cable. The cable you bought is for a bastardized device that uses an HDMI connector to output component video. The cable does not convert normal digital HDMI signals to analog component video. The seller was just taking advantage of people who don't understand this.
Does your TV have HDMI input? If so, a simple HDMI splitter will do the trick. Check out Monoprice.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
Intensity Pro Output 60FPS issue
By Zarukei in forum Newbie / General discussionsReplies: 2Last Post: 31st Jan 2012, 20:19 -
Blackmagic Intensity Pro Question
By wcwman18 in forum Media Center PC / MediaCentersReplies: 2Last Post: 22nd Jul 2011, 16:45 -
Minor(?) problem with Intensity Pro analog output
By Dandy J in forum Capturing and VCRReplies: 1Last Post: 18th Apr 2011, 21:58 -
Black Magic Intensity Pro Question
By compicatedstudios in forum Off topicReplies: 1Last Post: 30th Aug 2010, 20:06 -
Output HDMI using Blackmagic Intensity Pro
By kILLDR3n in forum Capturing and VCRReplies: 0Last Post: 25th Feb 2010, 11:34
