I've got a movie that is 2h6m in length.
Is there any software that will compress this file so it will fit on a DVD+R/-R ?
I can't use dual-layer disks on my System.....or my DVD Player (for television).
Any Suggestions ?
garystan
File size = bitrate x running time. Therefore, make the birate smaller, get more on.
You don't way what your source is, so you should start with a tree view from mediainfo.
However for general avi to DVD conversion you can use the free AVStoDVD or DVD Flick, or the payware ConvertXtoDVD. Burn to quality media with Imgburn for best results.Read my blog here.
There's lots of software you can use that will allow it to fit on a DVDR. Maybe you're under the impression that you can only fit up to 2 hours on a DVDR? Not true. In what format is this video? Anyway, you might try DVD Flick or Avs2DVD, among others. There are a ton of guides in the guides section of this site that are for just this purpose.
REPLY :
So far, I downloaded DVD Shrink and Blaze Media Pro. And it seems that the
winner is Blaze Media Pro. This program will "resize" the video, and then I use
Nero Vision to burn the DVD.
Apparently, DVD Shrink only works with DVD disks, not video files.
Blaze Media Pro, even though this is the "free trial" version, still works very
well.
i think the same applies to DVD Flick, it only works with DVD disks, not video
files.
Thanks for taking time to respond.
garystanLast edited by johns0; 26th Feb 2010 at 15:51.
That's right.
That's not right. When you click on the DVD Flick link, at the bottom of the new page are links to any guides for its use, including this one for creating DVDs from a variety of different kinds of source videos:i think the same applies to DVD Flick, it only works with DVD disks, not videofiles.
http://www.dvd-guides.com/content/view/229/59/
And lose the bold big letters. I can't even figure out to get rid of them when quoting you.Last edited by manono; 26th Feb 2010 at 17:28.
Garystan-I have reduced the font size of yout text,please use regular font size where needed.
WinRAR MPEG(video file) Compression Gone Haywire
By hech54 in forum ComputerReplies: 4Last Post: 20th Mar 2012, 14:13 -
Compress .AVI Videos To Have The Same File Size After Compression
By genoshaft in forum Newbie / General discussionsReplies: 11Last Post: 4th Jul 2011, 00:20 -
Reduce file size vs. compression question. Am I doing this right?
By Ronny G in forum Authoring (DVD)Replies: 9Last Post: 29th Dec 2008, 08:30 -
iso file compression?
By just in forum Off topicReplies: 3Last Post: 2nd Dec 2008, 12:03 -
compression and DVD Shrink
By snafubaby in forum Authoring (DVD)Replies: 2Last Post: 13th Dec 2007, 01:15
