I just wanted some input from all users. I bought my ZR10 MiniDV camcorder in 2000. Recently, I bought a JVC GR-D775U camcorder to burn DVDs of 35 or so miniDV tapes I have, spanning in dates from 2000-2007. This is because ZR10's tape mechanism kicked the bucket in 2007. 90% percent of the tapes from 2000-2005 have either corrupt or missing sound just like in the following video. Turn down your volume! What you see and hear is exactly how this video imported into my computer using FireWire and Pinnacle 12 software.
http://www.youtube.com/watch?v=MawU8FM4Rf0
So, the video was shot in the Summer of 2003. Could it really have deteriorated this much, or is audio still recoverable if played back on a high-end player?
Please help!
Results 1 to 15 of 15
LP mode allows for more footage on the tape by foregoing some of the error checking normally done. There are very frequently issues with play back of LP tapes on any camera except the camera used for recording. Even using the same model of camera as the original may not be enough to get clean playback. While it may be the tapes, I suspect, given the history of LP issues, that it is a playback issue with the camera and the tapes. One that may well be very difficult to resolve.
Read my blog here.
What about trying to find a high-end player? Could a professional grade head read all of available sound?
I have the exact same issue, only with a Canon Elura camera. Did you manage to find a player that could read the sound?
For an LP tape which won't play back on a different machine from the one on which it was recorded, a simple trick is to try to play it on yet another different machine.
I now have four different cheap mini DV camcorders for exactly this purpose. Some tapes work better on one, some on another. It's down to the head alignment, but unless you're going to adjust this yourself, having a few random alternatives is very useful.
btw, all four camcorders are nominally "correctly aligned" - certainly in SP mode, tapes recorded any one of them are interchangeable with any other. But for LP tapes, or even other SP tapes which are slightly "off", one machine is often far better than another. So obviously the alignment isn't identical between the four.
I picked fairly old + cheap machines to try to get some variation. Cost me very little from eBay. Brand new machines would hopefully be perfectly aligned, and not help at all!
Cheers,
David. -
That makes sense, thanks!
Do you find that head alignment varies between machines of the same model? In other words, do you think I would have a better chance of success if I looked on eBay for the same model as what was used to record on the tapes in the first place? This is in SP mode, by the way. -
since it's sp almost all cams should read your tapes ok. you might try a head cleaning tape first and also make sure the camera's audio type is set correctly for the tapes either 12 or 16 bit whichever was used.
I was under the impression that cameras automatically detect a tape's audio type. Are there cameras that allow you to specify the audio type for playback? My current camera (Canon ZR930) does not appear to have this ability, so perhaps it's detecting the wrong audio type? It does play back its own tapes fine.
If it's SP with perfect picture but no audio then you probably have another problem, not head alignment. It's still possible, but far less likely.
Some machines can only cope with one type of audio.
Is the audio lost when playing back on the machine straight to a TV, or only when capturing? If it's only lost when capturing, there are some obscure bugs in various capture tools that can cause this with some cameras, but it can be worked around.
Cheers,
David.
Audio & Video Conerting problem
By halfpiint in forum Newbie / General discussionsReplies: 6Last Post: 10th Jul 2011, 23:13 -
Am I really missing anything from not having an hd audio capable amp?
By yoda313 in forum Off topicReplies: 1Last Post: 23rd Dec 2010, 17:59 -
Can't Mux audio & video streams to MP4 without a problem
By spycam in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2010, 17:49 -
Audio missing when opening an Avisynth script in WMP & VirtualDubMOD
By aln688 in forum Video ConversionReplies: 3Last Post: 2nd Apr 2010, 06:09 -
Capturing from MiniDV Cam & Audio simultaneously...
By gtrgriff3 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Aug 2008, 19:56
