I have a lengthy (2 hour) mpeg-2 file. I created it using capture software for this tv-to-USB video creator called Dazzle. I fed it 16:9 video, and it captured all of it, but squished it into 4:3. So all of the info is there, but its squished.
I'm trying to create a quick DVD using DVD Creator Pro software. When I input the video, it comes in as 4:3, and when I play it on my DVD player it's the same squished 4:3.
Is there some way to convert this- or tell it to be- 16:9 without totally re-compressing the video?
I did it in TMPGEnc, but its totally re-compressing the video and its taking hours.
Results 1 to 15 of 15
DVD Patcher can patch the VOB files with a 16:9 header flag. IFOAR2WS can change the IFO files to match. Then burn a new copy.
Read my blog here.
The only difference between a 4:3 and 16:9 MPEG file on DVD is only a flag that tells the player which aspect ratio to use. They are both 720x480 (NTSC) or 720x576 (PAL). All you have to do is tell you DVD authoring software the file should be displayed at 16:9.
Any idea how to do that in DVD Lab Pro? It seems to want to just take the aspect ratio of the video and use that, and not change anything?
Thanks everyone, the DVDPatcher seemed to work well, and I found something on the same site called ReStream which seems slightly better- and I think it worked!
Both are great tools. ReStream has the limitation of only working on an elementary video stream, whereas DVD Patcher can patch program streams (MPG files) and VOBs, so it can be used to fix an already authored DVD, something ReStream cannot do. Keep both in your kit, as there is a place for both.
Read my blog here.
You can fix it with VSO ConvertXtoDVD (current version) and it is quite quick.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Does it re-encode the video ? The patching methods are compliant and lossless because there is no re-encoding.
I get the impression, from the number of times someone here posts "ConvertXtoDVD can do it", that people are using ConvertXtoDVD to solve problems with files by re-encoding, rather than using the proper tools to fix the issue. While ConvertXtoDVD may be able to solve the problem by re-encoding the file, this causes a generational loss in quality, whereas the proper methods do not. ConvertXtoDVD is not a general panacea to all DVD related issues.Read my blog here.
Yep! This was exactly my original issue. I didn't want to re-encode. The quality is one thing, but for a 2 hour DVD quality mpeg... it takes FOREVER! I figured there was a way to just patch the file.
And, indeed, after playing around with everything DVDPatcher was the way to do this. Thanks again!
My only minor complaint with DVDPatcher is when you load a file, it doesn't pre-set all the options to what the original video was at.
So if you want to change the aspect ratio, you do that but then you have to remember to go one-by-one to the other options to make sure you put them back to where they were. For example, the height and width need to be put back to 720 x 480 even though the video was always 720 x 480 and I have no intention of changing that. -
stretching video
By feh in forum Video ConversionReplies: 2Last Post: 5th Dec 2010, 09:15 -
My HD Video and YouTube stretching it.
By Scooter_NJ in forum Video Streaming DownloadingReplies: 7Last Post: 3rd May 2009, 03:58 -
stretching video resolution
By Enforcer83 in forum Video ConversionReplies: 5Last Post: 1st Jan 2008, 15:21 -
quickly fix reversed field order w/o re-rendering MPEG-2?
By miamicanes in forum Video ConversionReplies: 2Last Post: 14th Sep 2007, 22:19 -
Nerovision 6: 16:9 Stretching to 4:3 on 4:3 Monitor
By markannab in forum Authoring (DVD)Replies: 14Last Post: 30th May 2007, 06:23
