Ok. Try this:Originally Posted by freetza
On TMPEG go to Settings/Advanced and change your Source Aspect Ratio: to 16:9 525 line (NTSC) and change Video arrange Method: Center(custom size) 352 x 352.
Also check that under Settings/Video your output is 352x480 and 4:3 525 line NTSC.
Now do a one minute clip and see what it looks like.
kwag
Closed Thread
Results 631 to 660 of 784
KVCD.Net - Advanced Video Conversion
http://www.kvcd.net
I tried one more time to not get the audio to glitch on my Apex by increasing the minimum bitrate to 700. Still no go at anything mpeg1 at x480. Oh well. Cybermage, do a test with the standard TMPGenc mpeg1 template and change the video to either 352x480 or 480x480. If the audio glitches even with the standard template, then you are in the same boat as me and there is nothing you can do to get the audio not to glitch using Kwag's template. At x480 anyway. I use it all the time now for VCD stuff at 352x240.
I also guess other people are just fortunate with what their DVD players can do. Anything I encode at mpeg1 x480 is squished. Period. Even 480x480 I just did, it was squished. It's also squished while TMPGenc is encoding it. My DVD player won't unsquish it. But even if it did, the audio problem is still there anyway. Bummer.
I've been using cq mode for SVCD now thanks to this thread. (using the standard template.) I don't know how, but with solid quality it seems to save quite a bit of space over using 2-pass VBR. I don't know why, though. Logic says it shouldn't do that. I did Heat (170 minutes!) on two discs in SVCD at a cq of I think 80 or 82 and 224 audio. It's just a drama and is also in 16:9, but still.
I just encountered the same problem. I did as above, still incorrect aspect ratio, but after I changed Video arrange Method: Center(custom size) to 352x224 it's ok.Originally Posted by kwag
Will this mean that I have halfed the horizontal res?
(Why does this occur?)"The future is no longer what it used to be"
Are you playing back with WinDVD or PowerDVD.Originally Posted by mute
NOT with Media Player?
kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net
@Deusxmachina
Your encoding shouldn't look squished in TMPEG's window.
If it does, your input aspect is wrong.
http://www.kvcd.net
Playback in WMP always looks good for me, why I don't know. But playback on my set-top DVD was also squished first, but when I did as I said above, I get an OK aspectratio on my set-top (and that's what counts for me ;) ) Oh, and the 'preview' in TMPGEnc looks just as on the set-top, so the WMP-result fooled me at first...Originally Posted by kwag
Another question kwag though;
- Why are there artifacts in _lowmotion_ sequences? Is that because of the large number of B and P frames?"The future is no longer what it used to be"
mute:Originally Posted by mute
Don't use WMP to playback 352x480, because it doesn't understand aspect ratios.
Did you burn one of the samples in the site?
Did they displayed correctly on your standalone player?.
Please do this to verify that the format does indeed play in your DVD player.
Then we take it from there.
There shouldn't be any artifacts during playback. Even in high motion scenes they are barely seen.
If you noticed low motion artifacts in a movie, lower the P frames to 12.
This is not necesary for most movies, but I have seen this behaviour in some movies.
However if you set the value to 12, your file will be larger.
http://www.kvcd.net
Ok Kwag, just one more question. This should be my last bug to work out. I've gotten everything to look great, except when i play it back on my dvd player, it's just a little jerky. Maybe you are familiar with this problem, but if your not i could upload a clip to you or something to show you what i'm talking about. Thanks
Mike
I believe you said earlier that you are reading the .d2v directly from TMPEG?. Is that the case?.Originally Posted by freetza
If so, when you ripped your DVD, did you set "Forced Film ON" ?.
There are too many variables, and I need to know how you ripped, are you frameserving or directly reading the .d2v?
http://www.kvcd.net
Kwag, thanks for the last tip, it worked perfectly. Now I have a new question for you. I have some movies I downloaded that are DIVX files. They are 30 FPS, and when I encode them using your template, I change the FPS to 30 to keep the frame rate the same. However, this creates files that are over 800 MB, so I cannot fit them on a CD. How can I convert the frame rate from 30 fps down to 23.97 fps but keep the audio in sync with the video?
THanks so much
Chris
To be honest, I'm not sure!.Originally Posted by cgreer00
That's why I don't like DIVx files. Because they are all completely inconsistent as to frame rates and resolutions.
I think that's another topic. Converting DIVx file to MPEG.
But I think that anyway you convert that file, it's not going to play back very smoothly.
Anyone care to add something here, links, etc ?.
http://www.kvcd.net
I'm trying to think back if it squished it during my previous mpeg1 tests using the standard template at 480x480. I can't remember now. I know it always squished it at 352x480, though, and my last one-minute test of 480x480 yesterday using your template was squished.Originally Posted by kwag
I know for certain all of my previous tests at 352x480 were squished, even in the TMPGenc window while encoding. But, doing nothing but switching to an mpeg2 template at the same resolution wouldn't squish it.
And you said it is squished in your display window but then your DVD player unsquishes it. Apparently my DVD player can't unsquish.
I mean, I know the difference between 4:3 and 16:9 input... when I was trying anything and everything to get it to not squish in mpeg1, I tried all combinations... 4:3 input and 1:1 output or whatever, 16:9 and 4:3, 16:9 to 16:9, etc. The only time things didn't look squished was if the source material was 4:3 because then it would squish it into a 16:9-type display. But, that was actually still squished, of course.
So, I dunno. I think I give up. :-\
Hmmm... seems to me that until I start doing my own DVD rips and save them in "pure" avi, or avi with huffy codec, I'm stuck with whats available on the net. That ,almost 90% of the time, means a divX format.
It occured to me that there are many of us following the wise one (Kwag) and even Kwag himself who are converting files in TMPEG which were from quality divx rips. Perhaps we could start a users group or ring, where we post the files we've ripped for each other to download, and save hours of encoding the same darn thing?
For example how many of us have downloaded a version of K-Pac or Training Day this week? Is it necessary for each of us to endure the encoding process? Maybe in a group we could each download and encode 1 movie, per Kwags templates, and post them somewhere for the others to share and maybe there'd be 10 or 20 movies there that are already done?
I'm new and maybe I'm missing something, sorry if this is stupid and theres some obvious reason this cant be done.. but if it can be, how? Whats needed and how many of us want to do this?
,[/quote]
Dude, to implement that proposal means breaking the law. You can't share films you dont own the original of
Dont worry..... I'm not one of those "I am holier than thou" people. Personal opinion doesn't come into it
It would just seem a shame to get this thread closed, as has happened after a few similar requests in the past.......I guess thats what they invented the private message for
Noted.Originally Posted by kwag
Yes, I've tried the clips from the site and they worked...Originally Posted by kwag
I fiddeled quite a lot with the aspectratio last night, so right now I'm not sure of anything anymore. I'll go through it tonight again and try to document my efforts..."The future is no longer what it used to be"
Kwag,
I have used your template numerous times now, and the preview in TMPG has Always been squished. When the source was 4:3, and I played it back on my set-top, it appeared fine (which I Really don't understand.)
However, when the source was 16:9, and I played it back on the settop, by switching my display to anamorphic (unsqueeze), it displayed perfectly.
And as a testament to the quality of Kwag's work, my display is a Sony LCD front projector, projected onto a 7-foot-wide screen (viewing distance 13 feet). Even projected that large, the quality is excellent, on par I would say with the poorer DVD transfers. Great work Kwag. I label my burned cd-r's "KVCD"
First of all Grat job Kwag!!!!!
I have a problem can you gyus help me? all my movies are DiVX in fim format 640+240 or 576+240 .... 640*352 and so on.... When i use the kwag template i can´t get a correct aspect ratio in the output file....
Can anyone explain me how.... i´ve tried the the 1:1 source aspect ratio; 2,11:1; 4:3; but nothing..... Is there a formila to calculate the custom size???
Thanks gyus!!!
SpeeD72
Hi scav
Do you encode movies in film format??? if you do what kind of crop do you use??? keep aspect ratio, ratio2, center custom????
When you play the movie in the pc how is it??? squished, normal???
if the movie we´r enconding doesn´t occupied the must of the half pal resolution why dont we encoded it in quarter resol?????
Thanks again guys!!!
Speed72,Originally Posted by Speed72
Most of the movies I've incoded were in film format. That is, I used avisynth to IVTC them, feed to TMPG, and set the frame rate in Kwag's temp to 23.976.
I don't do any cropping and because the labels of the the fields related to aspect ratio in the TMPG Settings dialog are thoroughly non-intuitive and seemingly contradictory. I've never changed them:
Video Stream setting/Aspect Ratio - 4:3 525 lines NTSC
Advanced/Source Aspect Ratio - 4:3 525 line (NTSC 704x480)
Advanced/Video Arrange Method - Full Screen
Windows Media Player and the preview screen in TMPG both show a horizontally squished image.
Hey Scav. Thanks for the comments. And, BTW, why didn't I think of that! - KVCD - sounds pretty cool.Originally Posted by Scav
So, you've officially named the method!.
If it' ok with you, I'll change the name to that, and make references from now on to a KVCD method.
How's that?.
Regards,
http://www.kvcd.net
[quote]Dude, to implement that proposal means breaking the law. You can't share films you dont own the original of Dont worry..... I'm not one of those "I am holier than thou" people. Personal opinion doesn't come into it It would just seem a shame to get this thread closed, as has happened after a few similar requests in the past.......I guess thats what they invented the private message for [quote]
Sorry. I never thought of that. A wise man once said it is better to remain silent and thought a fool, than to open your mouth and remove all doubt."
and still, my private message box appears empty?
8)
hmmmmm...
KWAG
I used your template and converted a DVD rip of Shrek to be burned. It was 660 MB, and I put it on a CD. When playing it on my Apex 1100W DVD player, it looks and sounds great. However, the audio and picture is in sync, then goes out of sync, then gets in sync, then goes out of sync. This happens throughout the entire movie. Also, sometimes the picture slows down and gets a tad choppy. I upped the min bit rate to 600, and made the picture 240 instead of 480, like you advised. So what could be causing this problem?
Thanks!
Chris
Kwag (or anyone),
I have read every post in this thread and read guides, etc. everywhere as well. But I think I'm a little confused with a couple of things, so it's time to jump in.
I have been trying to create VCDs using Kwag's templates. The samples look good, and I have burned some of my own that look good too.
I am not currently doing DVD rips, but capturing DishNetwork via SVIDEO to my All-in-Wonder Radeon. Since first reading this thread I am capturing to MPEG1 (with ATI MMC 7.6), I think at around 6mbps, motion detection 98 (or whatever), 352x480, *not* deinterlacing. The caps look really good.
My question involves frame rate. Kwag's templates are for 23.97fps, which is great for FILM DVD rips. I know I can change the frame rate in the template, but can I take advantage of the smaller size of 23.97 vs. 30fps? Would IVTC be involved here? My understanding is that NTSC broadcast (or satellite broadcasting) is always at 30fps and I capture at 30fps. What happens if I capture at 23.97fps?
Bottom line: what is the best way for me to get the best quality/smallest size VCD files using Kwag's templates when the source is captures from DishNetwork??
By the way, I am playing back on an Apex 1100W, so I have tried raising the minimum bitrate to 600 as well.
Thanks!
Geoff
Hi Chris:Originally Posted by cgreer00
I think your Apex model doesn't like MPEG-1 VBR!.
Try something:
Increase the audio to regular 224 and try it again.
If this doesn't work, then I don't know!
http://www.kvcd.net
Hi Geoff:Originally Posted by gvarney
I also capture with a Big Dish C-Band and a 4dtv receiver.
I do IVTC on the captures and use the KVCD 8) template.
Just do IVTC with TMPEG, or better but a little more complex, use an AviSynth script with the decomb.dll filter.
With the decomb filter you can IVTC real-time as you encode!.
http://www.kvcd.net
Panasonic Rp-56Originally Posted by cgreer00
Sony NS300
Most Panasonic's and Sony's should work.
For insurance. Why don't you burn one of the 352x480 samples in the site and take it along to WalMart. Then you can try several models in the store and check that they display correctly and don't have any audio/video sync issues.
http://www.kvcd.net
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 02:53 -
how to shrink a movie to fit a dvd 5?
By just in forum Newbie / General discussionsReplies: 2Last Post: 30th Oct 2008, 00:58 -
makin the movie fit
By xstatictravis in forum DVD RippingReplies: 12Last Post: 11th Apr 2008, 09:52 -
makin a movie fit?
By xstatictravis in forum Authoring (DVD)Replies: 1Last Post: 8th Apr 2008, 21:30 -
AVI to DVD - Movie doesn't fit on screen
By tmac2085 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 11:18
