I'm looking for a good video conversion program for Windows 7 64-bit. I tend to download TV shows as I am not at home when they air (don't have DVR) so I can watch them. I like to put them on DVD as well which is why I'm looking for the conversion program as I prefer to watch on my TV then my small computer screen. Any suggestions?
Budget: The cheaper, the better, but can afford a few bucks.
Results 1 to 16 of 16
Most conversion apps works fine in win7 and you wont get any faster/better with a 64bit tool.
Use convertxtodvd or the free dvd flick or avstodvd to convert to dvd-video format. -
I was gonna suggest convertx2dvd, so I'll go further and suggest a divx compatible dvd player, or a jump drive and the western digital multimedia hard drive media player. You can save conversion time and still watch them.
64 bit is to do more with how much memory can be addressed than how fast the CPU is. In certain specific instances there are very definitely benefits, such as editing large, multi-layer images in photoshop, of multi-layer composites in after effect, for non-memory bound, CPU intensive applications like encoding there is little to be gained.
That said, I would suggest you seriously consider either w WDTV and USB HDD, or at least a DVD player that will play Divx/Xvid encoded files. The bulk of the files you are discussing will then play without conversion, and you can put half a standard season on a single DVD.Read my blog here.
Your best bet would be to download windows own Windows Live Movie Maker.
Why ? He isn't editing, just converting to make DVDs. WMM won't help him encode faster or do what he needs.
If he mist create DVDs (and I question the need to nowadays) something like AVStoDVD or the afore mentioned ConvertXtoDVD would be a much better optionRead my blog here.
Looks like the convertX seems to get the most votes.
I will look into that. Now as far as getting the USB key and such as you guys were suggestions, I didn't even know that was possible. Now, I'll just have to buy the new equipment.
What do you suggest I buy to use the USB key and such? I already have an 8gig USB key, would that work? what would I need to connect to my TV? -
in hitting nails it doesA hammer is easy to use, but that does not make it a universal tool.
A WDTV and a USB HDD would be the most flexible option, as it covers a wide range of formats. More restrictive but cheaper would be a Divx/Xvid capable DVD player. The Philips seem to get mentioned a lot. If you have a gaming console (PS3/XBOX then you may be able to use that)
Read my blog here.
virtualdub: input video distorted on 32 bit but not 64 bit
By iggogg in forum EditingReplies: 18Last Post: 5th Oct 2011, 02:34 -
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14 -
64 bit encoding program for MKV to MP4
By prk72 in forum Video ConversionReplies: 10Last Post: 30th Oct 2010, 15:11 -
32-bit program Micrografx on 64-bit windows vista?
By Obamargarine in forum ComputerReplies: 8Last Post: 11th Aug 2009, 19:56 -
Any Authoring program that RETAINS the Copy_Once bit ?
By mbextreme in forum Authoring (DVD)Replies: 6Last Post: 18th Jan 2008, 12:34
