I had a PC burn up a mother board or something the screen went black but still powers on. I tried new video card still no go. I bought a SSD/HDD quick adapter to hook to my IDE hard drive and try to read my info from it. I can't seam to find my Firefox bookmarks. Anyone know how to find them or where they are stored on the hard drive?
Results 1 to 11 of 11
Thanks stinkfist
On my Win7 install they are located at:
C:\Users\*username*\AppData\Roaming\Mozilla\Firefox\Profiles\*someweirdstring*.default\bookmarkbackups
If you're on XP it would be:
C:\Documents and Settings\*username*\Application Data\Mozilla\Firefox\Profiles\*someweirdstring*.default\bookmarkbackupsvalvehead// -
firefox calls it a profile. google backing up firefox profile and that should point you to the data.
http://kb.mozillazine.org/Lost_bookmarks
If you had backed them up, they would be listed in the file bookmarks-date.json or .html. the folder that normally stores them is
duitetbm.default.
At least that where I found mine.
Tony -
are you sure the issue was with overheating or a motherboad malfunction? Sometimes the power supply just gets "stuck" (I don't really know what's going on so I don't know what to call it). It causes the machine to power up and lights to come on but the computer never really boots up.
This happens after a power surge or storm usually and you have to unplug the power cord from the computer...hold the power button down for a few seconds, let go...then plug the computer back in and push the power button again.
I'm not saying it isn't any of the things you mentioned, just offering a possible solution if you aren't sure why it's doing what it is. -
Once you get your bookmarks back, install the Xmarks plugin and create an account. You can then use Xmarks to keep a backup copy of your bookmarks on their servers. You can also use it to syncronise bookmarks between multiple machines, which is handy if you have a laptop and desktop, for example.
Read my blog here.
Not for sure if it was a mother board or power supply or even a hard drive issue. I tried the unpluging thing and a new video card still no go. I only paid $100 for it. It is a Dell GX270. Worked great for surfing and what I need it for. But started using it for some HD video compressing when I should of just waited till my new pc was here and it burned up from running all night I believe.
Just need the bookmarks and thing off the HD. Thanks for the info guys.
Thanks stinkfist -
Why work hard instead of smart? Get MozBackup, ver. 1.4.10. Then, anytime you have a problem, you can quickly restore your settings.
xmarks works on Chroma and IE, too.
I use an extension called febe to make a backup of all my bookmarks, usernames, passwords, extensions, themes, and more. Very useful.
Donadagohvi (Cherokee for "Until we meet again")
Favorites and Bookmarks
By Jomapil in forum ComputerReplies: 3Last Post: 29th Dec 2011, 17:41 -
Encoding TV shows from DVD with bookmarks...
By nzdreamer55 in forum Newbie / General discussionsReplies: 2Last Post: 30th Nov 2009, 14:38 -
By nzdreamer55 in forum EditingReplies: 1Last Post: 25th Nov 2009, 02:40 -
Where do emails and bookmarks live in XP?
By GMaq in forum ComputerReplies: 3Last Post: 10th Feb 2008, 12:42 -
Womble MPEG Wizard - Bookmarks
By terrypin in forum EditingReplies: 0Last Post: 18th Jun 2007, 14:45
