Hello,
While I am burning DVD+R DL with Copy2DVD, I keep getting this error. I never had this issue before with Verbatim disc. But this is my third time in succession that it is happening now.
"2010-02-24 13:29:39 Error Write error at 2001408 (16) - Code 06 29 00 [Unit attention, Power On or Bus device reset occured"
I always use Verbatim and the speed is 2.4 X. I never had any issues till recently. This is from the same lot of discs that I have been using.
This is a new HP Machine and has the driver hp CDDVDW TS-T633P H130 [E] (Scsi)
Any ideas will be appreciated!!
P.S. Just tried a regular DVD-R. No issues with burning. Its only DVD+R DL.
Results 1 to 16 of 16
The only thing I've found on that drive is that it is probably in an HP TouchSmart of some sort.....maybe.
Thanks for the responses. This is a HP Touch Smart 300-1003 Series.
I have burnt 5 successful DVD+R DL before with the same Verbatim disc. But the last 3 have failed with the same error message.
Just curious, how would IMBGURN help? -
It's the best, period -- free or pay.
I hate to be a party pooper but.....that drive is basically a "laptop drive"...and the model
name sounds scarily similar to the old TSSCORP drives that have boatloads of horror story
user-reviews attached to them as I recall. -
Either use IMGBURN or buy yourself a external dvd burner. You're not going to know if you don't try....otherwise be stuck with burning only single layer dvd discs. Sounds like to me the culprit is the burning software that you're using. I'd rather waste one Verbatim DVD+R Dual layer disc than buying a new external dvd burner. I'm not fond of laptop dvd burners which is what you have.
P.S. TSSCORP is a collaboration with TOSHIBA & SAMSUNG. -
Before replacing the drive you should do these
1: Check for updated firmware and retest
2: Check cables - unplug and reconnect -
TSST drives are fine. I have several of them.
The worst laptop drives are those LG ones. Ugh.Want my help? Ask here! (not via PM!)
^^^^I've never had LG laptop dvdrw's. OP just needs to use IMGBURN and if it fails to burn then we know it's the drive.
To Bjs: How would you check the cables with that type of Touch PC? I'm just curious cause I've never worked on one of those HP touch screen pc's.
To OP: Are you using the burning software that came with the HP pc? That could also be the culprit of burn failure. Sometimes softwares have conflicts and could arise after awhile. I went to the HP website and see that it has cd/dvd burning software installed.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01897819&tmp_track_link=ot_faqs/t...007372&lang=enLast edited by budz; 28th Feb 2010 at 19:49. Reason: added a HP link
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
What is this device? (rf in-out with power supply?)
By cynikalhedonist in forum Capturing and VCRReplies: 11Last Post: 23rd Mar 2011, 11:11 -
mencoder Bus 16()?? error
By kabuto in forum Video ConversionReplies: 1Last Post: 14th Mar 2011, 03:03 -
Any device to drain and store residual power from partially spent batteries
By gll99 in forum Off topicReplies: 2Last Post: 22nd Jan 2011, 23:44 -
Slightly OT -- Power Supply for External USB HDD used with Portable Device
By GrayStrickland in forum Portable VideoReplies: 2Last Post: 25th Mar 2009, 14:50
