I would like to know how to use Wincron to use as a timer for MMC 7.5 so i can cpture with S-video thanks
You can use Wincron to launch the TV app, right-click and check properties on the TV portion of MMC launchpad, as I recall, the command line is MMC.EXE /TV+, then use the send keystroke function. I just bring the TV app up first and then just send the keystroke.
The keystroke to start recording, which you will find by pointing your mouse at the record button, is CTRL-R. By reading the help file, you will find that special keys, such as CTRL, cannot be sent directly but as I recall, the command is "% R". you can then schedule another CTRL-R at the end of the movie, remember to start a minute or two early.
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 17:12 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 01:24 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 20:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 22nd May 2007, 23:44
