Hello,
I am unsure what to use to rip my DVD's for backups.
I want to be able to rip DVD's using a 'command line' program (such as ffmpeg, but I'm not sure if ffmpeg does that).
Could anyone suggest a solution please?
Oh and i should mention that I am looking for a program for WINDOWS not Linux!
Nope, ffmpeg can't rip. I think dvdfab decrypter supports command line switches. Check the readme.
Thanks Baldrick, gave it a go and it works pretty good, I like the way it rips the entire DVD rather than just encoding the movie to a video file
"Ripping" is the single act of extracting information from a disc and dumping it to a file (ISO image, VIDEO_TS folder set, VOB files via IFO, etc).
Converting to "a file" is a separate process entirely. Sure, some programs do both ripping AND converting, but they often (as you've apparently noticed) really do a lousy job at it.
Why must it be command-line? That's sort of weird.
More DVD copying posts:
http://www.digitalfaq.com/forum/forumdisplay.php/copy-dvds-duplicate-32.html
https://forum.videohelp.com/forums/24-DVD-RippingLast edited by lordsmurf; 1st Mar 2010 at 13:32.
Thanks for the reply.
I understand this, but I noticed you mentioned the IFO files, how do these files enable you to copy data from a DVD? And in what way can they be used?"Ripping" is the single act of extracting information from a disc and dumping it to a file (ISO image, VIDEO_TS folder set, VOB files via IFO, etc).
I would prefer to use command line as they dont seem to need a proper installation to use, i.e ffmpeg does not require you to install you just need to have the file on your hard drive in a known location in order to use it. Also, using ffmpeg as an example again, it has proved to be a lot more useful than any GUI's I have tried... which is a lot. I like the idea that it is a very lightweight method of doing things. Plus as a side bonus it kinda helps me to learn more about commands and things like that.Why must it be command-line? That's sort of weird. -
WinX DVD Ripper?
By adrien23 in forum DVD RippingReplies: 8Last Post: 1st Nov 2020, 07:04 -
DVD Ripper
By lexus22 in forum Newbie / General discussionsReplies: 3Last Post: 13th Apr 2012, 11:49 -
Using All-In-One DVD ripper
By shuohshuoh@trashmail.net in forum DVD RippingReplies: 2Last Post: 11th Apr 2010, 12:47 -
DVD Ripper Suggestions
By Steverup in forum DVD RippingReplies: 1Last Post: 23rd Oct 2007, 11:14 -
dvd ripper
By not_aplicable in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 21:53
