hi i merged a screen captured avi video with camstudio with an avi movie video...using avs video converter the problem is that my merged video have really bad quiality when its plays the screen captured video with camstudio
how can i fix the problem so the camstudio movie will apear good also in the merged video.
the camstudio video alone plays good
another description for the problem:
camstudio recorded video(good quality alone) + avi video(good quality alone) = merged video with avs video converter(here the camstudio part plays really bad quality)
Join with something that doesn't reconvert like avidemux or virtualdub(set to video->direct stream copy). This will only work if the video has same properties.
Or if you want/must to reconvert be sure use a good codec like h264 or divx/xvid and high video quality setting/bitrate. -
hi do u know how do i change my video to have same properties? so i can merge them using virtualdub
First, you must know which codec the "non-Camstudio" video was compressed with.
Second, you'll have to re-encode the camstudio file with the same codec
(or same codec type --- e.g., DivX == Xvid == 3ivx,
except for the respective 4CCs) as the 2nd clip.
You'll learn how to tweak the encoder settings
until this gives you the quality you want to obtain.
--- EDIT ---
P.S.: I'm assuming the screen capture was encoded with a lossless codec,
being Camstudio 1.0 the best choice IMHO.Last edited by El Heggunte; 24th Feb 2010 at 23:17.
And ?hi i merged a screen captured avi video with camstudio with an avi movie video
Take note of video resolution conversions when merging
1: avi movies height x width
2: screen captures height x width
If both are not identical (use gspot to determine differences) then merging can not take place
Beware to set camstudios FPS correctly to reduce problems later (match fps value of avi movie)
If video resolution for screen capture is larger than that of avi movie it is most likely to be re-encoded and downscaled ... which can degrade quality somewhat ... only way to reduce the effect is prior to screen capture set video resolution for system to lower screen resolution ... reset when finished. -
is there out there any software that i can create a video with a type of text message in it instead of recording my screen and controlling the resolution?
unlike cam studio which record my screen but cant control the resolution
AVS Video Converter 7.1 Quality Problems
By toulsonguk in forum Video ConversionReplies: 0Last Post: 1st Jul 2011, 13:28 -
AVS Video Converter
By Huh...What? in forum Video ConversionReplies: 3Last Post: 31st Jul 2010, 10:55 -
AVS video converter
By jakewoodblues in forum Video ConversionReplies: 1Last Post: 20th Oct 2009, 16:41 -
CamStudio Recorded video won't play back in Quicktime
By imagine3 in forum Software PlayingReplies: 3Last Post: 29th Sep 2009, 15:23 -
avs video converter 6 help
By Hpy68 in forum Video ConversionReplies: 3Last Post: 5th Oct 2008, 21:53
