XP SP3, ATI Radeon HD 4550
primary: LCD monitor 1280x1024
secondary: HDTV 1920x1080 p
player: MPC-HC, DVXA enabled
Output is set to System Default:
DivX file can be played back on both displays
H264 file can only be played back on primary display; black screen if MPC-HC is located on the 2nd display
full-screen theater mode will work on second display for both DivX and H264
Output is set to VMR7 renderless:
Both DivX/H264 filse can only be played back on primary display; black screen if MPC-HC is located on the 2nd display
full-screen theater mode will work on second display for H264, but black screen for DivX
Output is set to VMR9 renderless:
No full-screen theater second display
Is there any setting that I am missing?
Thanks!
	Video overlay/hardware acceleration cause all this and it may be tricky to get it the way you want. I just set(keyboard shortcut) the hdtv to the primary when I play movies.
  HELP! Black screen/Blue Screen problemBy will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 10:30
  Did WinFF have a display screen at one time?By gastrof in forum Newbie / General discussionsReplies: 5Last Post: 18th Mar 2011, 02:38
  Playing Video on display 2 and display 1 goes blackBy sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 01:36
  LCD Screen: video plays on desktop but appearing black on big screen...By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36
  Screen goes black for half a second in Screen Virtuoso avi video stream.By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
