Hi. I want to rip a DVD (movie recorded from TV) to my HD, tried with DVDDecrypter ("Pack Header Not Found"), DVDShrink (freezes), ImgBurn ("Failed to Read..."), DVDFab ("Failed to Read...") and Windows Explorer (freezes), when processing the first .VOB movie file.
To make things easier, ripping only the audio will be ok, I tried with DVD Audio Ripper 4 but I got only the first 23 minutes.
Thanks in advance.
				Results 1 to 9 of 9
	My first guess is that you have a really messed up DVD.  DVD Decrypter should have been able to get it. You can try something like ISOBuster and see if it can recover the file. Or you might luck out with VOB2MPG and just get the MPEG file off it and demux the audio. But I suspect the disc has some major problems. DVD Decrypter should have been able to get it. You can try something like ISOBuster and see if it can recover the file. Or you might luck out with VOB2MPG and just get the MPEG file off it and demux the audio. But I suspect the disc has some major problems.
	Did you use DVD Recorder to record the show and did you finalized disc after?
	Can you put disc in computer drive, right click on it and see what files are there.
 If the disc is home made, you should not need any ripper, you can just copy(drag) files to your HD the same like any other file copy procedure.
	When you right click on disc in the drive and click OPEN, do you see VIDEO_TS.IFO file or just VOB files?
	Have you tried cleaning the DVD carefully with a micro-fiber cloth? That in combination with for instance ISOPuzzle has helped me with troublesome discs in the past. In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
  Trouble ripping DVD with subtitlesBy stig in forum DVD RippingReplies: 9Last Post: 22nd Feb 2012, 06:08
  Trouble with DVD Ripping: Need Some RecommendationsBy charmedlife417 in forum DVD RippingReplies: 9Last Post: 28th Sep 2011, 22:44
  Trouble ripping HDTV (.ts)By Julllie in forum DVB / IPTVReplies: 4Last Post: 7th Mar 2011, 11:12
  Trouble playing mp4 in VLC, audio is there, but no videoBy brdhsby5 in forum Newbie / General discussionsReplies: 6Last Post: 9th Feb 2010, 14:06
  Trouble getting video in time with audioBy JayxDee in forum ffmpegX general discussionReplies: 1Last Post: 27th Jul 2008, 09:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
