I'm running OS 8.6 on an 8100/100AV & would like to use Toast 4 Deluxe to convert some home movies to VCDs to view on my DVD Player. Toast 4's manual says it can create VCDs. I can capture the video no problem with the AV port and save as a QuickTime Movie (I have QT4 Pro) and can edit with VideoShop.
Problem: How do I get it to an MPEG that Toast'll accept? Movie2MPEG crashes w/ a Type 3 error. Do I need to capture it as something else?
I can't use iMovie or iDVD (although iTunes works great w/ Fake OS 9). What do I need to do?
If necessary, I have a 7600/132 at work that I can leave chugging during the off hours, but I'd rather do it all on the 8100 where the actual CDR is.
Results 1 to 1 of 1
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
