Page 2 of 2
FirstFirst 1 2
Results 31 to 33 of 33
    Feb 2010
    montreal canada
    it is de-interlaced to the max,with the plugin de-interlacer with movie magix and also when i resize it to 720p at 29.97
    it is de-interlaced a little bit with that too,does the process of putting in on a dvd interlaced it again !i don't know
    but when i look at it on my hdtv it is not interlaced fore sure,100 % sure about that.
    i am going to try a few things this week end,like boosting the colors to see if it does something.
    any suggestion to have the best image possible on the dvd.
  2. Originally Posted by luc13137 View Post
    sorry i think maybe you are right
    9000 kbps or 9 mbps is the same
    and 9800 would the dvd max ,but avs to dvd goes only to 9000
    I just wanted to be sure the max allowed by your software was reasonable. Some capture cards for example have a max bitrate of around 6000 kbps. 9000 should be good enough.
    Feb 2010
    montreal canada
    hey you all !do you know if
    would sony vegas pro9 or vegas movie studio platinum pro would give better results than
    movie magix edit pro 15 plus.
    i mean for stabilization and for re-encoding and final quality of image .
