Hi there, guys!
I would appreciate suggestions on freeware software I can use to split .AVis, .MPGs and the like.
I play my stuff with Videolan and it used to be able to split but now the function has disappeared.
Thanks a lot.
I use mpg2cut2 for mpg and virtualdub or avidemux for avi files.
At least with avi's you can use virtualdub, you set the start and stop points, make sure video it set to direct stream copy and then under file save the segment.
Freeware software to fix photos before printing
By kyrcy in forum ComputerReplies: 12Last Post: 25th Jan 2011, 15:07 -
MP4 editing > Freeware software that will do it!
By Bodh1 in forum Newbie / General discussionsReplies: 10Last Post: 30th Jun 2010, 01:59 -
Splitting/Joining files: new Freeware tool!
By Anonymous5394 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jan 2010, 15:38 -
Can anyone recommend a freeware screenwriting software?
By rijir2001 in forum Off topicReplies: 0Last Post: 25th Nov 2009, 23:44 -
Need CD Burning Software/Freeware
By Scooter_NJ in forum AudioReplies: 3Last Post: 5th Nov 2007, 22:52
