I know that autorun.inf/exe virus on a USB memory stick is a big problem. On my computer, to solve this problem, I just disabled the autorun using http://ask-leo.com/is_autorun_really_that_evil_and_if_so_how_do_i_turn_autorun_off.html
However, if someone does not disable the autorun, then the computer will immediately execute the exe virus when the USB is inserted.
My question is, how can antivirus software deal with this situation? It seems like, even with antivirus software, the computer will immediately execute the exe, before the antivirus has a chance to delete the exe.
	Create a folder on the USB stick and your C: drive called Autorun.inf . That will stop the Autorun.inf file from being able to be copied to the stick or drive to begin with.
 I found an app which sits in the system tray waiting for USB drive/stick to be attached and immediately intercepts the Autorun.inf file from running. Can't recall the name at the moment.
 Here's the link http://nunobrito.eu/ninja/Last edited by Soopafresh; 23rd Feb 2010 at 05:44. "Quality is cool, but don't forget... Content is King!"
	Why does that work?Create a folder on the USB stick and your C: drive called Autorun.inf . That will stop the Autorun.inf file from being able to be copied to the stick or drive to begin with.
	Windows looks for the first thing named AUTORUN.INF in the root directory of the drive,
 even if the Autorun.inf happens to be a directory , and in this case, , and in this case,
 the OS will not try to find the actual file AutoEvil.inf.
  Question about scanning OS partition using antivirus/antimalware softwareBy PartingShot in forum ComputerReplies: 8Last Post: 31st May 2011, 17:07
  Question about deleting USB drivers to fix lack of USB notificationBy jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 11:24
  Question why F-secure antivirus slows computer to almost zeroBy jimdagys in forum ComputerReplies: 7Last Post: 25th Dec 2009, 18:40
  Question about how Antivirus software can repair severe virus infestationBy jimdagys in forum ComputerReplies: 3Last Post: 3rd Dec 2009, 06:59
  Autorun Precedence - DVD & Autorun on the same discBy SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2007, 21:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
