Results 31 to 40 of 40
I took a quick look, don't have time to look at them properly yet, but a few observations: The "avirecomp" and "divx movie" both have difference bitrates, the avirecomp being quite a bit higher. Were either of those 700MB for the whole file? Regarding the source, it looks very blocky in places; perhaps turning on deblocking in the decoder may help. I'll have some more tomorrow.
Recompressing an over compressed source is never going to look pretty. But if you must...
Try MSU Smart Deblocking (to remove blocks from the source), resizing to 592x408 (to fix the aspect ratio), cropping away the black borders and news scroll (leaving 592x320, smaller frame = better compression) and a 2-pass encode with the Xvid codec. -
Well I got back to it tonight. I followed Jagabo's advice, then set the bit rate to 1022.
(according to your stated length of 1 hour 29 minutes the calculator in the Divx config gave this bit rate assuming 89 minutes,
700MB & 56kbps (original audio) )
I encoded it using Divx 685, which I happened to have installed, I set the quality slider to 5
on the 2nd pass.
I'm not sure what difference xvid would give, most seem to prefer it, perhaps Jagabo would comment on that.
here's the partial I did -
http://www.mediafire.com/download.php?znwwzjo21nj -
I find Xvid usually does a little better than Divx. But Xvid is a little slower. The difference is small enough that it's not really worth worrying about.
So, do you think I have a dying chance, or do I really have to back it up 400/400 mb on each cd?
Burning a Blu-ray is the next achievement. ;) -
It's really up to you whether you think the results are a fair compromise or not.
Use the MSU deblocking filter, and optional resize/trim, re-encode it in Virtualdub using the
suggested bitrate and then decide when you see the result. -
The down side of using a deblocking filter is that it leaves the video blurrier. The blocks are replaced with smooth gradients. At 15 cents a disc I would just split the game at half time and put it on two discs. I'd run it though Mpeg4Modifier and correct the PAR/DAR first though.
Here's your original sample after MSU deblocking, cropping and resizing to 592x320, about the same bitrate as your AviRecomp file:
http://kotuha.com/file/B4EEo-xvid.html
AviSynth with the addition of a DCT ringing removal filter would do a little better.Last edited by jagabo; 28th Feb 2010 at 20:18.
remove episode from the middle of 800mb AVI ?
By pribl in forum Newbie / General discussionsReplies: 16Last Post: 10th Nov 2011, 11:26 -
Blueray to a 700mb .avi file
By withmenilu in forum Blu-ray RippingReplies: 1Last Post: 24th Jun 2009, 06:07 -
Shrinking an AVI file from 1.4GB to 700MB
By DVantrease in forum Video ConversionReplies: 5Last Post: 28th Mar 2009, 20:11 -
bitrates for 650-700MB AVI to DVD
By ecc in forum Video ConversionReplies: 12Last Post: 20th Aug 2008, 19:26 -
900mb avi to 700mb vcd
By dck42069dck in forum Video ConversionReplies: 7Last Post: 4th Mar 2008, 14:33
