I'm trying to burn an 800mb avi, approximately 792mb. Technically, it can't be done because cd-r's can only accomodate 703mb.
I've tried to reduce its resolution of 720x408 to 640x360 and burning it then, only to realize Virtualdub isn't the best for that...
My audio is around 30mb of the video itself, in Mpeg 2 Layer 3.
Is there a way to get this file on a cd, or am I gonna have to split&burn to 2 cds to keep quality up?
NOTE: I have tried AVIRecomp, and the quality is not the best, but kind of acceptable. The thing is, I know there is some other way to get this file on a cd w/o losing that much quality. I'll try to get a picture up of the converted file.
P.S. I do not have a DVD Burner.
Results 1 to 30 of 40
Burning a Blu-ray is the next achievement. ;)
In virtualdub try direct stream copy for the video and set the audio to "full processing mode" then try changing either audio -> conversion, or the audio ->compression. A large amount of the data is the audio.
or am I gonna have to split&burn to 2 cds to keep quality up? -
What is the running length of the movie (minutes and seconds) and what bitrate of the audio?
Virtualdub is incredibly versatile and can easily do what you want - but there is a learning curve.
You can re-encode the video (2-pass) and use the existing audio as-is. Use a bitrate calculator to figure the bit-rate.
The Divx configuration box has a useful one. -
Ever heard of DVD's???
CD's are almost obsolete for burners now, if you haven't got a DVD burner it's time you upgraded -
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151192
$19.99
Treat yourself to one.You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
read the fine print::
P.S. I DO NOT have a DVD BURNER!
The running length of the movie is 1 hour and 29 minutes.
I tried to reencode the audio at a lower bitrate, and it was successful. The downside to that is that the speakers sounded muffled.
Burning a Blu-ray is the next achievement. ;) -
Here are some specific instructions for using Virtualdub.
Install the Divx codec if it's not already installed
Open your source in virtualdub.
Set Audio/direct stream copy
Select Video/ compression (choose Divx) / configure.
Hit "restore defaults"
Under rate control, choose 1st pass (fast)
Select the calculator icon to the right and set the running length, filesize desired, and audio bitrate and then accept.
On the "codec" tab, select "enhanced multitasking" (only of you have dual core or better)
OK out of the Divx config.
Select file/queue batch operation/ run video analysis pass
Select video/compression/divx/configure
Under rate control set multipass Nth Pass.
Move the quality slider to 4 or 5.
OK out.
Select file/queue batch operation/Save as AVI
Select file/job control.
Check "auto start" and both passes will encode. -
As was mentioned above , go buy a DVD burner for $20.
Any other method used to shrink it to fit on a single CD-R will reduce PQ by a good margin. Them's the facts. -
I don't have the divx codec... So what do I do
Download and install it... There's only so much fellow-forum members can do long distance.
You could also consider buying and burning to non-standard 90 minute CD-Rs. You'll have to search on the internet to find them. Burning to DVD or re-encoding to a smaller size or splitting and burning to 2 discs are probably easier choices. Do note that if you do decide to buy and try the 90 minute CD-Rs that you should burn them as slowly as your burner will allow to avoid failed burns. I personally recommend 4x or less burning speed for these discs. And you'll need a tool that supports overburning such as Nero (not sure if ImgBurn can do this or not. I know Nero can.).
An illegally downloaded movie off the internet already looks like crap at 800MB. Re-encoding to an even lower bitrate will only make it look worse. Could try trimming the opening intro and closing credits from the file and smart rendering in Virtualdub but I doubt you'll be able to trim 100MBs off the file.
*** Now that you have read me, do some other things. ***
If the OP isn't too sure on how to get the divx codec loaded onto his PC, I'm a bit doubtful on him being able to do this. And then there could very well be compatibility issues with his player. Just sayin'..
Currently, I am trying this method again. The first time I tried it, it was late at night, so as a result, I did not get to do both jobs. Today, hopefully, I will be able to do so.
I have looked at the XCD method and thought about trying it, but wouldn't know how to encode back into an avi.
NOTE: I am trying to burn the file for a backup purpose. I'm really trying to delete it once I get it burned to a cd that the quality is acceptable and > then my AVIRecomp mess that I made. Will try to get a picture up.Burning a Blu-ray is the next achievement. ;) -
This doesn't require any changes to your 800 MB file. Just select mode 2 when you burn your CD. The trouble with mode 2 is that there's less error correction so you're at greater risk of corruption.
Split it in two without any reencoding and put it on two CDs. Or use QuickPar split it into several smaller files with parity files. Burn the files to two CDs. The parity files will allow you to recover the file even if parts of it become corrupt.
In any case, if you're going to use CDs as backup you will need to have multiple copies. -
Idk. I have a bad case of premonition syndrome.
For some weird reason, I feel as if I WILL lose this video if i burn it to 2 cds mainly because there are 2 cds. Also, it would be a waste of space to take up 100mb of space for a split file. Even if 400/400, it's still waisting space. You still lose 600mb+Burning a Blu-ray is the next achievement. ;) -
Reencoding the video is going to cost you more in electricity than an extra CD. Well, not really. But why bother since you'll have to spend a lot of time learning to encode.
It's hard to diagnose any further without seeing the result and perhaps the source. In my setup, I've used xvid and divx; they both play on my standalone but the divx-encoded files are smoother - the player just handles them better. Can you post 20 - 30 MB's of the source ? One thing about Virtualdub is that it forces you learn the process, because it's all manual steps. However, that may be bad for some users - and the all-in-one convert program works better for them.
Extract segment with VirtualDub (no quality loss):
1) File -> Open Video File
2) Video -> Direct Stream Copy
3) Mark-in, Mark-out
4) File -> Save as AVI -
I uploaded them to loombo.com
Original Video.avi - 49.0 Mb
AVIRecomp.avi - 41.4 Mb
DivX movie.avi - 37.4 MbBurning a Blu-ray is the next achievement. ;) -
I had absolutely no luck downloading from "loombo.com".
In fact, IE8 closed the tab and said it was a malicious site.
Try http://www.mediafire.com/ -
remove episode from the middle of 800mb AVI ?
By pribl in forum Newbie / General discussionsReplies: 16Last Post: 10th Nov 2011, 10:26 -
Blueray to a 700mb .avi file
By withmenilu in forum Blu-ray RippingReplies: 1Last Post: 24th Jun 2009, 05:07 -
Shrinking an AVI file from 1.4GB to 700MB
By DVantrease in forum Video ConversionReplies: 5Last Post: 28th Mar 2009, 19:11 -
bitrates for 650-700MB AVI to DVD
By ecc in forum Video ConversionReplies: 12Last Post: 20th Aug 2008, 18:26 -
900mb avi to 700mb vcd
By dck42069dck in forum Video ConversionReplies: 7Last Post: 4th Mar 2008, 13:33
