the last time i shrunk a dvd9 to dvd5 was back in 2004/2005 and back then I always had very mixed results using dvd shrink. often during playback of the compressed dvd there would be several skips and pauses.
I have 2x dvd9 discs i want to compress to dvd5 for a backup but unsure of the best application to use, i want to avoid the old dvd shrink if possible which i see hasn't been updated for years.
if anyone can give me some advice it would be most appreciated!
	DVD Shrink is still good for what it does, and for small reductions, it is still the fastest option. If you have larger reductions, DVD Rebuilder with HCEnc as the encoder. Read my blog here.
	Agree with guns1inger. DVD Shrink is still good for smaller compression values. Otherwise use DVD Rebuilder with HCEnc.
	I've used DVD Shrink since 2004 and never do I think it caused skips/pauses. Might be your Burn Speed, Burning Program, DVD Player, Media, etc. It Started In Texas
	thanks guys
 i had a look at a few programs but as mentioned dvd shrink still seems to be the most popular, i am giving it a go now.
 selected deep analysis, maximum smoothness, also changed the maximum dvd size down to 4000MB to further prevent any glitches.
 EDIT: most probably could of been the media i was burning to back then, i have imation on hand which doesn't fail me for 1 to 1 backups or other video projects so hopefully it will go well.
	skips/pauses is from either
 (A) cheap media
 (B) trying to use the computer while it was transcodingWant my help? Ask here! (not via PM!)
  Will DVD Shrink shrink an ISO image?By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03
  Alternative to DVD Lab ProBy 557953 in forum Authoring (DVD)Replies: 7Last Post: 4th Jul 2010, 11:17
  software alternative to nero to put a dvd on my HWBy marlo in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2010, 07:36
  how to shrink a movie with DVD Shrink?By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59
  MoxiBox alternative - DVD recording problemsBy oprquestion in forum DVD & Blu-ray RecordersReplies: 1Last Post: 10th Aug 2007, 10:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
