OK, I have ONE problem to solve.
Comcast DVR to Panasonic HD Viera TV via HDMI cable = Full Screen HD and full screen standard.
Panasonic DVD to same Panasonic HD Viera TV via HDMI cable = Full Scrren DVD MOVIES playback.
Here's the issue...
Comcast DVR to Panasonic DVD via any method (S video, Components, co-ax, RCA) to Panasonic HD Viera HDMI = LETTERBOX HD channels (record & playback), and Full Screen Standard (record & playback).
Is there ANYTHING I can do with this Comcast junk to give me full sreen DVD record & playback?
Results 1 to 11 of 11
HD channels aren't valid for DVD recording without conversion so I'd guess that the Panasonic DVD recorder is doing the best it can, which is to record them as letterboxed 4:3 in standard definition.
Okay, but I also have an Sony RDRHX715 (It has an HDMI jack), and I have the same problem with it on Comcast. But on Direct TV, I have it hooked up, and it records HD channels with full screen and in HD 1080i.
Why can the Sony work on Direct but not Comcast cable? -
I'm moving you to our dvd recorder section. And PLEASE do not cross post.
Your Motorola HD cable box can't be set up to output 720x480 anamorphic widescreen via any analog connection other than its component line out, but your DVD recorder only has S-Video and composite for its line inputs.
See this thread: https://forum.videohelp.com/threads/314275-Comcast-HDTV-cablebox-to-DVD-recorder-How-do-ILast edited by usually_quiet; 22nd Feb 2010 at 15:34. Reason: Add link
You need a Component to S-video converter. Your STB only outputs letterboxed 16:9 from it's composite or S-video outputs. Many DVR/STBs are like this. Here's a link to a converter.
http://www.ipmart.com/main/product/LENKENG,LKV7611,Component,to,Composite,,S,Video,Con...hp?prod=130401Last edited by jjeff; 22nd Feb 2010 at 17:23.
Recording from DVR Cable Box to DVD Recorder crops the sides
By Bumbie in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Jan 2012, 14:40 -
Microsoft hooking up with Comcast for the xbox 360 tv service?
By yoda313 in forum Off topicReplies: 1Last Post: 5th Oct 2011, 18:38 -
My first post: connrccting a DVD to a comcast DVR to record from ther DVR
By retired_guy in forum Newbie / General discussionsReplies: 10Last Post: 24th Jul 2011, 19:54 -
Help hooking up Panasonic DVD recorder to Comcast cable HD DVR
By KeithJFro in forum Authoring (DVD)Replies: 2Last Post: 22nd Feb 2010, 15:20 -
Recording a game from a Comcast DVR to a DVD recorder
By ConfusedinSC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Dec 2008, 13:18
