This weekend my pc was infected with the antivirus pro 2010 virus and unfortunately had to do a full system recovery. I have been in the process of reinstalling my software when I developed a problem with autogk. When I try to encode a new avi file, I get a VirtualDubError. I have done this type of encode many, many times without a hitch and now I can't seem to be able to fix this problem. Since last night, I have downloaded almost every codec under the sun and nothing seems to help.
I would appreciate any help on this issue... thank you
here's the log from autogk and some additional info from GSpot:
[2/22/2010 9:28:36 AM] AutoGK 2.55
[2/22/2010 9:28:36 AM] OS: Windows Vista (6.0.6000).2
[2/22/2010 9:28:36 AM] Job started.
[2/22/2010 9:28:36 AM] Input file:
C:\Users\Patrick\Downloads\alt.binaries.movies.div x\Untitled.avi
[2/22/2010 9:28:36 AM] Input codec: XviD
[2/22/2010 9:28:36 AM] Source duration: 1h 35mn 58s 800ms
[2/22/2010 9:28:36 AM] Output file:
C:\Users\Patrick\Downloads\alt.binaries.movies.div x\Untitled_agk.avi
[2/22/2010 9:28:36 AM] Output codec: XviD
[2/22/2010 9:28:36 AM] Audio 1: 192 Kbps CBR MP3 2ch
[2/22/2010 9:28:36 AM] Subtitles: none
[2/22/2010 9:28:36 AM] Format: AVI
[2/22/2010 9:28:36 AM] Target size: 700Mb
[2/22/2010 9:28:36 AM] Audio 1 settings: Auto
[2/22/2010 9:28:36 AM] Started encoding.
[2/22/2010 9:28:36 AM] Source resolution: 720x304
[2/22/2010 9:28:36 AM] Source fps: 25
[2/22/2010 9:28:36 AM] Analyzing source.
EXCEPTION: Cannot open file
"C:\Users\Patrick\Downloads\alt.binaries.movies.di vx\agk_tmp\interlace.log". The system
cannot find the file specified
[2/22/2010 9:28:39 AM] Job finished. Total time: 3 seconds
VirtualDub Error
Avisynth open failure:
DirectShowSource: Could not open as video or audio
No combination of filters could be found to render the stream
GSpot Info:
ACM Base msacm.ac3filter ** Missing file: ac3filter.acm
Results 1 to 1 of 1
x64 MeGUI DirectShowSource
By darkw1zard in forum Video ConversionReplies: 9Last Post: 1st Sep 2014, 17:16 -
Directshowsource error with StaxRip!!?
By Stb1990 in forum Newbie / General discussionsReplies: 0Last Post: 18th Apr 2010, 19:58 -
DirectShowSource error in Ripbot264
By reiter der hoelle in forum Blu-ray RippingReplies: 1Last Post: 15th Dec 2008, 03:22 -
Avisynth Directshowsource Problem
By Robert Simandl in forum Video ConversionReplies: 3Last Post: 2nd Jan 2008, 08:41 -
DirectShowSource freezes VirtualDub
By PlayWithFire in forum Newbie / General discussionsReplies: 3Last Post: 11th Oct 2007, 02:07
