How can I disable a menu item in a DVD? For instance, if the second button is "Subtitles" I want it to be skipped in the navigation. If the cursor is in the first button, it must go straight to the third.
Open the DVD in PGCEdit. Right-click on the menu in question and hit 'Menu Buttons' followed by right-clicking on the 'Subtitles' button (or any others you might want to disable). In the new 'Menu Editor' screen go Hide Button->Jump To Non-deleted Button. 'OK' and 'Close' to get back to the main screen, save your work, and test it out.
How to remove or disable area limitations on Sony DVD player?
By coody in forum DVD RippingReplies: 22Last Post: 25th Feb 2012, 03:21 -
Button to link to PGC in another Video Title Set + disable audio in cell
By c627627 in forum Authoring (DVD)Replies: 3Last Post: 2nd Jul 2010, 03:04 -
Edit dvd menu button
By canaQ in forum Authoring (DVD)Replies: 8Last Post: 24th Feb 2010, 07:13 -
Philips DVD player DVP5990K - is there a way to disable HDCP?
By ademarfj in forum Newbie / General discussionsReplies: 6Last Post: 30th May 2009, 22:32 -
Cannot disable DVD subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 8th Aug 2007, 16:56
