Hello everyone,
First let me start by apologizing for taking up forum space with a question like this, but it seems to have been asked before and no one has responded with a suitable answer/solution. My problem is as follows: I just started using TMPGEnc Authoring works 4 in an attempt to create more visually dynamic menus. The program works as expected when authoring and burning a single .avi file to DVD, but when I try to do the same thing with multiple .avi file, i.e. a TV. Show series I come across an "Access is Denied (Error code 0x80070005)" when I attempt to convert it into DVD files. EVREYONE replies that the file is in use somewhere else, and I would agree if someone else were posting this question, but I assure you the files are not in use anywhere else, and to make sure I downloaded an unlocker tool to double check. I also read replies saying it was based on space, which I have over 50 gigs free, on file structure, so I moved my "working" folder to C:/ and then to E:/ the root's of both of my HDD's. I am out of ideas and could really use some help! Thank you in advance.
-The Roo
Other possible points of interest:
App version: 4.0.4.24
*It crashes at various points through out the conversion from 0% right up to 51% being the highest i have got before recieving the error. -
What does Pegasys Inc. support say about this problem?
*** Now that you have read me, do some other things. *** -
My apologies ... although this is an old thread, it popped up as the first and only topic-specific google search result regarding this TMPGENC access error code, so I wanted to post the solution that I subsequently found by happenstance. The surprisingly simple answer had nothing to do with the TMPGENC input files or the setup within TMPGENC, and instead I had simply run out of space in the partition where I was trying to create a media output file from TMPGENC. Some overdue file maintenance clearing up that partition did resolve the problem.
tmpgenc authoring works 4 storage space error
By tommcd64 in forum Authoring (Blu-ray)Replies: 3Last Post: 3rd Oct 2011, 15:15 -
Avi2DVD file access denied
By Imeil in forum Video ConversionReplies: 1Last Post: 27th Aug 2011, 08:29 -
Access denied to some files on one of my USB drives
By cal_tony in forum ComputerReplies: 6Last Post: 15th Apr 2011, 15:53 -
Invalid audio bitrate error on TMPGEnc Authoring Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 12th Jun 2010, 23:13 -
avi access denied solved
By herdofem in forum ComputerReplies: 1Last Post: 4th May 2009, 21:52
