the drive was working fine till the other day even burned a data dvd 30 or so minutes before I found the issue well the drive will read dvd's but not able to record or burn anything it goes through the process like it burns the files but it won't really end up on the dvd as it errors out when checking the dvd and tried multiple dvd's same issue also have xp as operating system.
I have made multiple data and video dvd's and haven't had a issue until the other day. I tried to burn with the drag and drop with xp and nero software as well. tried removing the hardware via hardware installed and restarting no luck checked Imapi CD-burning COM service tried running and disabled. anyone have any ideas?
It probably won't help, but try burning with ImgBurn, then if it fails, take a look at the burn log and maybe post it here. That might give you some clues. If it's a hardware problem with the drive, consider replacing it.
And this is the DVD Recorder Forum. Moving you to the DVD & Blu-ray Writers Forum. -
Post a burnlog.
*** Now that you have read me, do some other things. ***
Problem with Sony DVD RW DRU-830A
By VOD0708 in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Jan 2010, 15:43 -
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 15:10 -
Disappointed with Sony DRU-190A - lots of coasters !!!!
By paulfoel in forum DVD & Blu-ray WritersReplies: 6Last Post: 26th Feb 2009, 16:56 -
where to get original Sony DRu-820a DVD Firmware
By scustalow in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jun 2007, 12:00 -
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
