I have a bunch of raw footage I rendered out using Pinnacle as DVD-Compliant MPGs. Now, it seems to me that in theory, I should be able to use something simple and fast to just rip these over to vobs and whatnot to make some DVD-videos. I could use Pinnacle to re-encode them as DVDs, but I'd be looking at 1-2 hours per file, and I have about a dozen of them.
Is there something out there that can just do it? I don't care about menus or chapters (this is just for archival purposes), so maybe what I am looking for is a simple container changer (the way mkv2vob does it's thing in a few seconds, this is what I am looking for). Or maybe I am totally wrong here and what I want to do isn't as easy as a job as I think. But I always thought vobs were just mpgs with a different file container (.vob not .mpg) and then a few ifos and all that rubbish that is small enough to be created in seconds.
Sorry, I don't have a clear enough idea of what I need for google (or even searching on here) to be much of a help.
VSO ConvertXtoDVD is one of the fastest encoders around in my experience. However it really depends on your computer specs as to whether the authoring will be fast or slow. A fast processor, good quality ram and adequate hard disk space all play a role.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Assuming they are in fact DVD compliant, you could use GUIForDVDAuthor to simply author them into a DVD with no re-encoding.
You do not want to use something that re-encodes the video if it doesn't need to, no matter how fast it may be.Read my blog here.
Thanks, I will try that GUIforDVDAuthor thing and see how it turns out.
I have used ConvertXtoDVD before, and I am usually completely unhappy with the video quality. Converted some PAL footage to NTSC using it before and it came out like puke. -
GUIforDVDAuthor didn't like me. I will probably just continue to procrastinate until my HDD crashes and the footage is lost in time.
Unfortunately this tells us nothing useful.
Error messages ?
What in particular doesn't it like about you ?
Can you post a mediainfo tree view of the files in question ?
You could also try the free DVD StylerRead my blog here.
MP4 web streaming (fast start) options
By BLboy in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2011, 19:16 -
2 mpg stills: same encode options, vast quality difference ??? (linux)
By jungle5150 in forum Video ConversionReplies: 7Last Post: 26th Jul 2009, 11:14 -
How to convert DVDs to AVI (fast, easy, 90% quality retained)
By guns1inger in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2008, 09:56 -
Need easy dvd->mpg for SFF jukebox
By no_such_user in forum DVD RippingReplies: 0Last Post: 4th Jun 2007, 09:47
