How which simple free tool to change container from m2ts to mkv ?
Regards
T.
My source file is m2ts.
When I try to open mkvtoolnix : it only see the DTS track and not the video H264 codec inside...
BTW, I've had to "force" to open m2ts file. By default, .m2ts are not included inside the "all supported media file" in the file type dialog box... -
Another option is Haali muxer (comes with haali media spitter)
or MakeMKV if this is from a BD for example
or you could use tsmuxer, extract raw streams, then mkvtoolnix to re-wrap
or eac3to
I think that behaviour is new with the new versions of mkvtoolnix, I think older releases worked fineBTW, I've had to "force" to open m2ts file. By default, .m2ts are not included inside the "all supported media file" in the file type dialog box...Last edited by poisondeathray; 21st Feb 2010 at 13:48.
thanks, mkvtoolnix works. but I have another question, how could I add chapter to MKV with mkvtoolnix ? not random.
Under the chapter editor? See http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvmerge-gui.html#chaptereditor
Or use a simple tool like MKV Chapterizer that add chapters at a custom interval.
M2TS to AVI - best free tool?
By CompVid in forum Video ConversionReplies: 9Last Post: 19th Jul 2016, 16:10 -
Why convert m2ts to mkv ?
By dude905 in forum Video ConversionReplies: 5Last Post: 31st Jul 2011, 10:17 -
How to convert MKV / MP4 to m2ts
By Bonie81 in forum Video ConversionReplies: 0Last Post: 9th Jun 2011, 14:47 -
Free MKV to DVD tool
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 15th Jul 2010, 00:37 -
Is there a way to convert a m2ts to mkv without directshow?
By damdirtyape in forum Blu-ray RippingReplies: 2Last Post: 2nd Sep 2008, 09:54
