I used to ripped movies and put them on DVD5, for backup.
With two DVD burners, Can any version of Nero let me just do a disc duplication with DVD9 ?![]()
No.
You may already know this, but most commercial movies can be backed up to a DL disc if you get rid of the extra languages, subs and other crap and only select the main movie. Once the DVD is decrypted, DVDShrink is still a good choice. Then burn the resulting file to a DL disc with ImgBurn. This combo has been working for me for quite a long time. I have AnyDVD HD, but DVDFab works also for decryption.
I don't use Nero at all any more, but it might work if you use the correct decrypter, then use Nero. But DVDShrink and ImgBurn seem a lot easier, and a lot cheaper.
Is most of these encryption schemes used defective sectors ? to defeat ISO type bit by bit backup ?
Shouldn't ISObuster type of bit by bit copy work for two layers DVD to DVD copy ?
Unless the writable DL DVD cannot duplicate the format or the capacity or .. of a factor DVD.
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 12:37 -
I want to backup DVD9 movie to single 4.5G blank disc
By byungsoo in forum DVD RippingReplies: 1Last Post: 6th Oct 2009, 01:09 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 20:17 -
Created DVD(UDF) in Nero, works on some computers, not all
By ir0n_ma1den in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2009, 22:51 -
Nero works with CDs not with DVDs
By fiiido in forum DVD & Blu-ray WritersReplies: 13Last Post: 23rd May 2008, 04:44
