I decided to use this external drive today, it has been inactive for 2 yrs. I've had it boxed up and shelved. Anyhow, the amber light on the power supply indicates theres power until I plug the 5 pin connector into the drive. The light then goes out and theres no power. Suggestions?
what's the 5 pin connector? ata power is 4, and sata is 15. if you think it's the power block then remove the drive from the enclosure and hook it up internally or get a ata/sata hard drive usb connector and try that.
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 04:03 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53 -
Power Shut Down Issue
By Snakebyte1 in forum ComputerReplies: 11Last Post: 6th Dec 2010, 07:50 -
Power issue? Hauppauge 1600 only works when I disconect my video card
By John32118 in forum Capturing and VCRReplies: 4Last Post: 11th Jul 2010, 12:56 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 23:15
