Hello fellow enthusiasts! I'm hoping someone can suggest something to address my query. I capture video using my Pinnacle Studio 500 USB device. This came with Studio 10. If I recall it was called "Studio In A Box" (?) I am using Studio 12 to capture. Here's my problem: I am wanting the ability to set a time for the app to begin capturing just as time shifting is an option in some capture cards and software. I also have Nero 9. This DOES allow time shift recording....but does not like the Pinnacle USB device and simply won't work with it. I've contacted Pinnacle about this but basically got a "non answer".
Sooooo.....I tried fooling with some stuff like Chris TV. Again, the Pinnacle Studio 500 USB does not play well with others. Then I had a revelation. If I could find the process name for the actual capture, I could set this as a scheduled event in Windows. No such luck. When Studio 12 is open, and you choose the capture option, there IS no specific process that shows up in Task Manager or Process Explorer.
There have been only 2 instances where I actually got the app to capture on a schedule. 1) Using Easy Macro Recorder to actually click the CAPTURE button (this only worked once). 2) It actually worked one time with Nero...never again.
Any ideas? Please do not simply suggest buying another product.![]()
Life is like a game of poker. If you can't spot the sucker after a few minutes...then you ARE the sucker.
The problem is "the Pinnacle Studio 500 USB does not play well with others".
I've used Windows task scheduler and other script programs in the past to start capture programs to a clock but find you are always fighting screen saver and Windows power settings so results are unpredictable. I've moved on to PVR programs.
http://www.iopus.com/guides/winscheduler.htm
http://en.wikipedia.org/wiki/Task_Scheduler
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/ballew_commandline.mspxRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Vertical lines with Pinnacle Studio 14/510 USB card
By karebo in forum Capturing and VCRReplies: 0Last Post: 11th Dec 2011, 16:54 -
USB 500 capture
By kortmann in forum Capturing and VCRReplies: 2Last Post: 18th Sep 2010, 19:44 -
Pinnacle 500 USB
By Dem Pyros in forum Capturing and VCRReplies: 20Last Post: 26th Aug 2010, 13:18 -
Pinnacle usb 500
By kortmann in forum Capturing and VCRReplies: 2Last Post: 26th Aug 2010, 00:50 -
Pinnacle 500-USB?
By beene in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2008, 04:13
