Hi all.
I just purchased a Blackmagic Intensity Pro to record Xbox 360 gameplay. Recording works fine, my problem is that I cannot output any video to my monitor. No 480i or 720p. I have an HP 2009m monitor which has a DVI input, so I am using an HDMI to DVI cable to go from the Intensity to the monitor. All I get is 1) a black screen or 2) a check cable message. There is no "signal out of range" message; my monitor supports 720p (I have watched 720p TV through my Comcast HD cable box). Also, I have played Xbox in HD through this monitor, however the setting said 1280x720 instead of 720p (aren't they the same?).
So my question is, do you think an HDMI splitter will solve this problem? I would go from my Xbox to the splitter, then one cable to the monitor and the other to the capture card.
Am I in need of a new display? Is the DVI input the problem? Any insight would be GREATLY appreciated.![]()
Does the monitor work conected directly to the XBox 360 HDMI->DVI-D?
Computer monitors are problematic for direct progressive video. An LCD-TV would be more reliable.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
720p (or 480p) is the only option for that computer monitor. The BlackMagic loop should work. An HDMI active splitter should work.
Figured out the problem, when both of the HDMI ports are occupied on the Blackmagic, my video card won't work. So if the video card is already up and running, the HDMI ports get locked. I guess that's a problem with my motherboard. Anyway, the HDMI splitter should work.
Blackmagic Intensity Shuttle
By mayhampixi in forum Capturing and VCRReplies: 5Last Post: 11th Nov 2013, 20:11 -
Blackmagic Intensity Pro Help.
By MoonVid in forum Capturing and VCRReplies: 1Last Post: 4th Nov 2011, 16:10 -
Blackmagic Intensity Pro.
By liamb96 in forum Capturing and VCRReplies: 8Last Post: 18th Oct 2010, 16:20 -
Blackmagic intensity pro help
By Smify123 in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2010, 11:19 -
BlackMagic Intensity?
By StEaLtHsHoT in forum Capturing and VCRReplies: 32Last Post: 12th Dec 2009, 16:18
