  1. Click image for larger version
    As you can see in the picture, the weird signs are actually Turkish characters but whatever i did i can not make them look like the actual Turkish characters, i also tried View > Options > Subtitles > Default Style > Turkish (162) but it didn't fix it, also Google ing didn't help me.
    USA
    You might look through similar threads in this forum, such as this one: https://forum.videohelp.com/threads/315940-Trying-to-(unsuccessfully)-use-Hindi-Subtitl...ovies-Any-Help
    Or others may have better advice.
    And welcome to our forums.
    Feb 2008
    Twin Peaks
    Just venturing a guess but you might try opening the subs in subtitle workshop and then exporting them as .sub, or whatever and see if it's a glitch in the subtitle stream.
  4. @ redwudz
    That topic didn't help me that much, i believe there should be a fix without translating the subtitles and stuff.
    Subtitle workshop didn't work for me, says that the subtitle is bad or a unsupported format (.srt)
