    May 2009
    I've been using Handbrake to convert my DVD movies I've recorded for my Ipod Touch. I notice an "anamorphic" setting: The choices are none, strict, loose, and custom. I've read the material in the Handbrake guide but am confused:
    1. Can someone provide an "anamorphic for dummies" explanation of "anamorphic?"
    2. Is there one setting I should generally use? If not, what determines my choice?
    Thanks very much.
    Paul
    May 2009
    P.S. What choice should I make regarding "keep aspect ratio"? It seems to default to that if "anamorphic" choice is "none".
