So I just converted an mkv containing DTS audio into DVD for burning... the problem, which I've experienced with another dl'd mkv with dts audio, is that during the conversion process for some reason the audio starts to crack in random locations.... I've only had this problem twice so I'm not overly worried BUT as I am new to most of this I would like to understand if its an issue with avs converter concerning DTS, if my dl'd version just isn't up to snuff, or whether my burning process with nero isn't up to snuff (which I doubt..) any help would be greatly appreciate as I don't know where to really begin the troubleshoot other than trying other applications....
Results 1 to 20 of 20
I know you don't want to try other tools, but frankly I wouldn't use either of those space wasters. I believe the issue lies with AVS Converter, and would suggest AVStoDVD as a free alternative that will do a far better job. I don't believe the issue, in this case, comes from burning with Nero. I wouldn't use Nero simply because Imgburn is far better and takes a 100's of MB less space than Nero.
Ditch AVSConverter and try AVIStoDVD insteadRead my blog here.
I'll give it a shot... Nero's my homie for the moment.. (one education at a time)
So I have a better question I think... as I'm newbin' it, I've learned little about muxing and whatnot... should I be splitting some of this stuff up and then deal with it? Basically will I continue to have problems (whether miniscule or not) with "do it all" programs like avsconverter and avstodvd? I don't mind steppin up to the plate in research and education... I'd rather perfect this process as much as possible..I'm sure that if I'm dealing with dl's I'll be converting no matter what, but is it better (overall) to convert seperate streams when trying to build my movie collection?
The beauty of a program like AVStoDVD is that it basically is built up of all the manual steps - it demuxes the source, processes it with avisynth, encodes with HCEnc, remuxes and authors - all the steps you could do manually. But it automates them for you. Yes, if you were an experienced purist you might change the type of script it creates to use a different deinterlacer when resizing, or a different resizer (you can change this in the program anyway) and other little tweaks around the edges, but essentially you are getting the right process, done by the right tools. You can even see and edit the script it creates, so can make these tweaks if you really need to. I think it makes a good compromise between the full blown process, and beginner level all-in-one. It hides the worst of the complexity away for the beginner, but lets you tweaks and change things as you learn more.
Read my blog here.
I took your advice and I dl'd avs2dvd which is completely different from my experience with avsconverter... first off... upon install I had it install avisynth and the haali splitter... I already had vlc and cccp installed as a codec pack... The first thing I did was ad family guy something something dark side (mkv) and as it seemed most settings were correct as far as I know (besides the fact that I changed the auto setting from PAL to NTSC should I have done this?) I tried to start the process... the first thing that pops up are error dialogues with not much to say in the way of whats going on... I am currently trying another mkv file and so far seems to be working with different results... my first question is why I got these errors and if I needed to install all these things for functionality.. (mostly the haali splitter thing) my second question is do I need to make sure there are no conflicts between existing programs?
haali splitter is used for opening mkv files correctly. avisynth is the scripting tool that does most of the video processing before the encoding.
As for the error messages - without seeing them I can really tell you what they mean.
One thing to make sure of - rename any long file names to something simple. Anything with symbols or odd characters may cause problems.Read my blog here.
I'm utilizing another mkv now and it seems to be doing its thing (both files had crazy long names but this one seems to be working)... however in my output directory I see a log file and then the m2v file only... does this mean I'm going to end up without audio? The next question is if I do end up with two files for video and audio such as ac3(not sure if I will) and m2v then how do I burn these files to dvd.. I was assuming I could utilize nero6 like I do with iso or vobs... I also noticed that even though I got errors last time I exited their dialogues and when checking the output folder saw that there were m2v file, log, and then the folders containing the video_ts/audio_ts... this file isn't doing that but no errors.. I guess for first use I'm completely confused... I still have some time before it finishes so this may be for nothing but I also wanna make sure that I shouldn't stop the process and change anything... should the setting have been changed to NTSC for instance? I figured that made more sense for the U.S. but I have no idea if it has anything to do with the input file... any basic info about avstodvd would be great because it seems to be much more configurable than avsconverter I just know little to nothing about it.
What you are seeing is AVStoDVD working through the file. First it does the video, then it does the audio, then any subtitle streams. Once it has all the elements encoded and prepared, it muxes them into an authored DVD structure. You just have to be patient and let it work through the file.
Unfortunately there are no guides listed, although if you search you may find some tips around the traps.Read my blog here.
Everything worked as it should have...! At least for my second try/file....Seems like a great program I look forward to learning more about it... however I renamed the longfilename mentioned b4 and have retried the process.. within two seconds of start the error dialogues come up again.. 3 of em... They are in another language to me and I would love to alienate this problem if someone will help. I think it will be a great learning situation... is there a way (I noticed copytext as an option) to post this error here so that I might figure it out?
OS: Windows XP Home Edition, SP2
CPU: AuthenticAMD, AMD AMD Phenom(tm) II X2 550 Processor, MMX @ 3120 MHz
Application data:
VmVyc2lvbjogV2xGQlhVSlFWRlphUkU1RFJrTlZKQ2xTT3lRN1 ZpQXN
BQWRWUHlFOEl6QnpaSHQrZHpNa0lqc2tJelpGY25SOWVHcC9Se mM3Uj
NKNGIzRkRNUT09DQpJbWFnZUJhc2U6IDFDNDAwMDAwDQpFaXA6 IDRCN
EFBMjANCkVheDogM0FGMDAwMA0KRWN4OiAzOUE2MjdDDQpFZHg 6IDAN
CkVieDogMA0KRXNpOiAzOUE2MUM0DQpFZGk6IDM5NjAwMDANCk VicDo
gMTMyM0RDDQpFc3A6IDEzMjJCMA0KLTENCkNvZGUgPSBbMjA0X Q0KLS
AwDQotIDIwNA0KLSAyMjcNCi0gMA0KLSBbXQ0KPiBDOlxQcm9n cmFtI
EZpbGVzXEFWU3RvRFZEXFF1RW5jXFF1RW5jLmV4ZQ0KDQpRdUV uYw0K
MCwgNywgNSwgMA0KUXVFbmMgdjAuNzUNCkNvcHlyaWdodCAoQy kgMjA
wNC0yMDA4DQpRdUVuYy5leGUNCjAsIDcsIDUsIDANClF1RW5jD QoNCj
4gQzpcV0lORE9XU1xzeXN0ZW0zMlxudGRsbC5kbGwNCj4gQzpc V0lOR
E9XU1xzeXN0ZW0zMlxrZXJuZWwzMi5kbGwNCj4gQzpcV0lORE9 XU1xz
eXN0ZW0zMlxBVklGSUwzMi5kbGwNCj4gQzpcV0lORE9XU1xzeX N0ZW0
zMlxtc3ZjcnQuZGxsDQo+IEM6XFdJTkRPV1Ncc3lzdGVtMzJcV VNFUj
MyLmRsbA0KPiBDOlxXSU5ET1dTXHN5c3RlbTMyXEdESTMyLmRs bA0KP
iBDOlxXSU5ET1dTXHN5c3RlbTMyXFdJTk1NLmRsbA0KPiBDOlx XSU5E
T1dTXHN5c3RlbTMyXEFEVkFQSTMyLmRsbA0KPiBDOlxXSU5ET1 dTXHN
5c3RlbTMyXFJQQ1JUNC5kbGwNCj4gQzpcV0lORE9XU1xzeXN0Z W0zMl
xvbGUzMi5kbGwNCj4gQzpcV0lORE9XU1xzeXN0ZW0zMlxNU0FD TTMyL
mRsbA0KPiBDOlxXSU5ET1dTXHN5c3RlbTMyXE1TVkZXMzIuZGx sDQo+
IEM6XFdJTkRPV1Ncc3lzdGVtMzJcU0hFTEwzMi5kbGwNCj4gQz pcV0l
ORE9XU1xzeXN0ZW0zMlxTSExXQVBJLmRsbA0KPiBDOlxXSU5ET 1dTXH
N5c3RlbTMyXENPTUNUTDMyLmRsbA0KPiBDOlxXSU5ET1dTXHN5 c3Rlb
TMyXE1GQzQyLkRMTA0KPiBDOlxXSU5ET1dTXHN5c3RlbTMyXE1 TVkNQ
NjAuZGxsDQo+IEM6XFdJTkRPV1NcV2luU3hTXHg4Nl9NaWNyb3 NvZnQ
uV2luZG93cy5Db21tb24tQ29udHJvbHNfNjU5NWI2NDE0NGNjZ jFkZl
82LjAuMjYwMC4yMTgwX3gtd3dfYTg0ZjFmZjlcY29tY3RsMzIu ZGxsD
Qo+IEM6XFdJTkRPV1Ncc3lzdGVtMzJcQ0xCQ0FUUS5ETEwNCj4 gQzpc
V0lORE9XU1xzeXN0ZW0zMlxPTEVBVVQzMi5kbGwNCj4gQzpcV0 lORE9
XU1xzeXN0ZW0zMlxDT01SZXMuZGxsDQo+IEM6XFdJTkRPV1Ncc 3lzdG
VtMzJcVkVSU0lPTi5kbGwNCj4gQzpcV0lORE9XU1xzeXN0ZW0z MlxEZ
XZJTC5kbGwNCkRldklMOiBBIHBvcnRhYmxlIGltYWdlIGxpYnJ hcnkg
aW4gZGV2ZWxvcG1lbnQNCkFieXNtYWwgU29mdHdhcmUNCkRldk lMOiB
BIHBvcnRhYmxlIGltYWdlIGxpYnJhcnkgaW4gZGV2ZWxvcG1lb nQNCj
EuNi42DQpEZXZlbG9wZXIncyBJbWFnZSBMaWJyYXJ5IChEZXZJ TCkNC
kNvcHlyaWdodCCpIDIwMDAtMjAwMg0KVW5kZXIgTEdQTCBMaWN lbnNl
DQpEZXZJTC5kbGwNCjEuNi42DQpEZXZlbG9wZXIncyBJbWFnZS BMaWJ
yYXJ5IChEZXZJTCkNCmVoPw0KT3BlbiBTb3VyY2UNCg0KPiBDO lxXSU
5ET1dTXHN5c3RlbTMyXFFVQVJUWi5kbGwNCg0KNi41LjI2MDAu MjE4M
A0KNi41LjI2MDAuMjE4MA0KDQo+IEM6XFdJTkRPV1Ncc3lzdGV tMzJc
Y29tZGxnMzIuZGxsDQo+IEM6XFdJTkRPV1Ncc3lzdGVtMzJcV0 lOU1B
PT0wuRFJWDQo+IEM6XFdJTkRPV1Ncc3lzdGVtMzJcV1MyXzMyL mRsbA
0KPiBDOlxXSU5ET1dTXHN5c3RlbTMyXFdTMkhFTFAuZGxsDQo+ IEM6X
FdJTkRPV1Ncc3lzdGVtMzJccnNhZW5oLmRsbA0KPiBDOlxXSU5 ET1dT
XHN5c3RlbTMyXFNlY3VyMzIuZGxsDQo+IEM6XFdJTkRPV1Ncc3 lzdGV
tMzJcV0lOSU5FVC5kbGwNCj4gQzpcV0lORE9XU1xzeXN0ZW0zM lxDUl
lQVDMyLmRsbA0KPiBDOlxXSU5ET1dTXHN5c3RlbTMyXE1TQVNO MS5kb
GwNCj4gQzpcV0lORE9XU1xzeXN0ZW0zMlxXSU5UUlVTVC5kbGw NCj4g
QzpcV0lORE9XU1xzeXN0ZW0zMlxJTUFHRUhMUC5kbGwNCj4gQz pcV0l
ORE9XU1xzeXN0ZW0zMlx3ZG1hdWQuZHJ2DQo+IEM6XFdJTkRPV 1Ncc3
lzdGVtMzJcbXNhY20zMi5kcnYNCj4gQzpcV0lORE9XU1xzeXN0 ZW0zM
lxtaWRpbWFwLmRsbA0KPiBDOlxXSU5ET1dTXHN5c3RlbTMyXER TT1VO
RC5ETEwNCj4gQzpcV0lORE9XU1xzeXN0ZW0zMlxLc1VzZXIuZG xsDQo
+IEM6XFdJTkRPV1Ncc3lzdGVtMzJcbXNkbW8uZGxsDQoNCjYuN S4yNj
AwLjIxODANCjYuNS4yNjAwLjIxODANCg0KPiBDOlxXSU5ET1dT XHN5c
3RlbTMyXEREUkFXLmRsbA0KPiBDOlxXSU5ET1dTXHN5c3RlbTM yXERD
SU1BTjMyLmRsbA0KPiBDOlxXSU5ET1dTXHN5c3RlbTMyXEQzRE lNNzA
wLkRMTA0KPiBDOlxXSU5ET1dTXHN5c3RlbTMyXGR4bWFzZi5kb GwNCg
0KNi40LjkuMTEyNQ0KNi40LjkuMTEyNQ0KDQo+IEM6XFdJTkRP V1Ncc
3lzdGVtMzJcdXJsbW9uLmRsbA0KPiBDOlxXSU5ET1dTXHN5c3R lbTMy
XERSTUNsaWVuLkRMTA0KPiBDOlxQcm9ncmFtIEZpbGVzXENvbW 1vbiB
GaWxlc1xBaGVhZFxMaWJcQWR2ckNudHIuZGxsDQoNCkFoZWFkI FNvZn
R3YXJlIEFHDQpBZHZyQ250ciBNb2R1bGUNCjEsMiwxMiwgMjMw OQ0KQ
WR2ckNudHINCkNvcHlyaWdodCAoYykgMTk5NS0yMDAzIEFoZWF kIFNv
ZnR3YXJlIGFuZCBpdHMgbGljZW5zb3JzDQpBZHZyQ250ci5ETE wNCjE
sMiwxMiwgMjMwOQ0KQWR2ckNudHIgTW9kdWxlDQoNCj4gQzpcV 0lORE
9XU1xzeXN0ZW0zMlxwZXJmb3MuZGxsDQo+IEM6XFdJTkRPV1Nc c3lzd
GVtMzJcQXZpU3ludGguZGxsDQpIb21lcGFnZTogaHR0cDovL3d 3dy5h
dmlzeW50aC5vcmcNClRoZSBQdWJsaWMNCkF2aXN5bnRoIHZpZG VvIHB
yb2Nlc3Npbmcgc2NyaXB0aW5nIGxhbmd1YWdlDQoyLCA1LCA4L CA1DQ
pBdmlTeW50aCAyLjUuOA0KqSAyMDAwLTIwMDggQmVuIFJ1ZGlh ay1Hb
3VsZCBhbmQgb3RoZXJzDQphdmlzeW50aC5kbGwNCjIsIDUsIDg sIDAN
CkF2aXN5bnRoIDIuNQ0KDQo+IEM6XFByb2dyYW0gRmlsZXNcQV ZTdG9
EVkRcTGliXGZmbXMyLmRsbA0KPiBDOlxXSU5ET1dTXHN5c3Rlb TMyXF
dTT0NLMzIuRExMDQo+IEM6XFByb2dyYW0gRmlsZXNcQVZTdG9E VkRcT
GliXEdldFN5c3RlbUVudi5kbGwNCj4gQzpcUHJvZ3JhbSBGaWx lc1xB
VlN0b0RWRFxMaWJcTmljQXVkaW8uZGxsDQo+IEM6XFByb2dyYW 0gRml
sZXNcQXZpU3ludGggMi41XHBsdWdpbnNcRGlyZWN0U2hvd1Nvd XJjZS
5kbGwNCkhvbWVwYWdlOiBodHRwOi8vd3d3LmF2aXN5bnRoLm9y Zw0KV
GhlIFB1YmxpYw0KQXZpc3ludGggRGlyZWN0U2hvdyBSZWFkZXI gcGx1
Z2dpbg0KMiwgNSwgOCwgNg0KRGlyZWN0U2hvd1NvdXJjZSAyLj UuOA0
KqSAyMDAwLTIwMDggQmVuIFJ1ZGlhay1Hb3VsZCBhbmQgb3RoZ XJzDQ
pEaXJlY3RTaG93U291cmNlLmRsbA0KMiwgNSwgOCwgMA0KQXZp c3lud
GggMi41DQoNCj4gQzpcUHJvZ3JhbSBGaWxlc1xIYWFsaVxNYXR yb3Nr
YVNwbGl0dGVyXHNwbGl0dGVyLmF4DQoNCkhhYWxpIE1lZGlhIF NwbGl
0dGVyDQoxLjkuNDIuMQ0KQ29weXJpZ2h0IChDKSAyMDA0LTIwM DcgTW
lrZSBNYXRzbmV2DQoxLjkuNDIuMQ0KSGFhbGkgTWVkaWEgU3Bs aXR0Z
XINCg0KPiBDOlxQcm9ncmFtIEZpbGVzXEhhYWxpXE1hdHJvc2t hU3Bs
aXR0ZXJcbWt6bGliLmRsbA0KPiBDOlxQcm9ncmFtIEZpbGVzXE hhYWx
pXE1hdHJvc2thU3BsaXR0ZXJcbWt1bmljb2RlLmRsbA0KPiBDO lxQcm
9ncmFtIEZpbGVzXEhhYWxpXE1hdHJvc2thU3BsaXR0ZXJcbWt4 LmRsb
A0KPiBDOlxXSU5ET1dTXHN5c3RlbTMyXGRldmVudW0uZGxsDQo NCjYu
NS4yNjAwLjIxODANCjYuNS4yNjAwLjIxODANCg0KPiBDOlxQcm 9ncmF
tIEZpbGVzXENvbWJpbmVkIENvbW11bml0eSBDb2RlYyBQYWNrX EZpbH
RlcnNcRkZEU2hvd1xmZmRzaG93LmF4DQoNCkRpcmVjdFNob3cg YW5kI
FZGVyB2aWRlbyBhbmQgYXVkaW8gZGVjb2RpbmcvZW5jb2Rpbmc vcHJv
Y2Vzc2luZyBmaWx0ZXINCjEuMC43LjMwNjQNCmZmZHNob3cNCk NvcHl
yaWdodCCpIDIwMDItMjAwOA0KR05VIEdQTA0KZmZkc2hvdy5he A0KMS
4wLjcuMzA2NA0KZmZkc2hvdw0KQ0NDUA0KDQo+IEM6XFdJTkRP V1Ncc
3lzdGVtMzJcRElOUFVULmRsbA0KPiBDOlxQcm9ncmFtIEZpbGV zXENv
bWJpbmVkIENvbW11bml0eSBDb2RlYyBQYWNrXEZpbHRlcnNcRk ZEU2h
vd1xsaWJhdmNvZGVjLmRsbA0KPiBDOlxQcm9ncmFtIEZpbGVzX ENvbW
JpbmVkIENvbW11bml0eSBDb2RlYyBQYWNrXEZpbHRlcnNcRkZE U2hvd
1xsaWJtcGxheWVyLmRsbA0KPiBDOlxQcm9ncmFtIEZpbGVzXEN vbWJp
bmVkIENvbW11bml0eSBDb2RlYyBQYWNrXEZpbHRlcnNcRkZEU2 hvd1x
mZl9saWJkdHMuZGxsDQo+IEM6XFByb2dyYW0gRmlsZXNcQ29tY mluZW
QgQ29tbXVuaXR5IENvZGVjIFBhY2tcRmlsdGVyc1xWU0ZpbHRl ci5kb
GwNCmh0dHA6Ly9zb3VyY2Vmb3JnZS5uZXQvcHJvamVjdHMvbXB jLWhj
Lw0KR2FiZXN0DQpWb2JTdWIgJiBUZXh0U3ViIGZpbHRlciBmb3 IgRGl
yZWN0U2hvdy9WaXJ0dWFsRHViL0F2aXN5bnRoDQoxLCAyLCAwL CAwDQ
pWU0ZpbHRlcg0KQ29weXJpZ2h0IChDKSAyMDAxLTIwMDggR2Fi ZXN0D
QpWU0ZpbHRlci5kbGwNCjEsIDIsIDAsIDANClZTRmlsdGVyDQp DQ0NQ
DQoNCj4gQzpcV0lORE9XU1xzeXN0ZW0zMlxsM2NvZGVjeC5heA 0KDQp
GcmF1bmhvZmVyIEluc3RpdHV0IEludGVncmllcnRlIFNjaGFsd HVuZ2
VuIElJUw0KTVBFRyBMYXllci0zIEF1ZGlvIERlY29kZXINCjEs IDUsI
DAsIDUwDQpMM0NPREVDWC5BWA0KQ29weXJpZ2h0IChDKSAxOTk 3IEZy
YXVuaG9mZXIgSUlTDQpMM0NPREVDWC5BWA0KMSwgNSwgMCwgNT ANCk1
QRUcgTGF5ZXItMyBBdWRpbyBDb2RlYyBmb3IgTWljcm9zb2Z0I ERpcm
VjdFNob3cNCg0KPiBDOlxXSU5ET1dTXHN5c3RlbTMyXHFhc2Yu ZGxsD
Qo+IEM6XFdJTkRPV1Ncc3lzdGVtMzJcd21hZG1vZC5kbGwNCj4 gQzpc
V0lORE9XU1xzeXN0ZW0zMlxtcDRzZG1vZC5kbGwNCj4gQzpcV0 lORE9
XU1xzeXN0ZW0zMlx3bXNkbW9kLmRsbA0KPiBDOlxXSU5ET1dTX HN5c3
RlbTMyXHdtdmRtb2QuZGxsDQo+IEM6XFdJTkRPV1Ncc3lzdGVt MzJcb
XA0M2Rtb2QuZGxsDQo+IEM6XFdJTkRPV1Ncc3lzdGVtMzJcbXB nNGRt
b2QuZGxsDQo+IEM6XFdJTkRPV1Ncc3lzdGVtMzJcbXNhZGRzMz IuYXg
NCj4gQzpcV0lORE9XU1xzeXN0ZW0zMlxhY2VscGRlYy5heA0KD QpTaX
BybyBMYWIgVGVsZWNvbSBJbmMuDQpBQ0VMUC5uZXQgQXVkaW8g RGVjb
2Rlcg0KMS40MA0KQWNlbHBEZWMuYXgNCkNvcHlyaWdodCAoQyk gMTk5
Ny05OSBTaXBybyBMYWIgVGVsZWNvbSBJbmMuDQpBY2VscERlYy 5heA0
KMS40MA0KQUNFTFAubmV0IEF1ZGlvIERlY29kZXINCg0KPiBDO lxXSU
5ET1dTXHN5c3RlbTMyXG1wZzRkczMyLmF4DQo+IEM6XFdJTkRP V1Ncc
3lzdGVtMzJccWR2LmRsbA0KDQo2LjUuMjYwMC4yMTgwDQo2LjU uMjYw
MC4yMTgwDQoNCj4gQzpcV0lORE9XU1xzeXN0ZW0zMlxtc3NjZH MzMi5
heA0KPiBDOlxXSU5ET1dTXHN5c3RlbTMyXHdtdmRzMzIuYXgNC j4gQz
pcV0lORE9XU1xzeXN0ZW0zMlx3bXY4ZHMzMi5heA0KPiBDOlxX SU5ET
1dTXHN5c3RlbTMyXGlyNDFfMzIuYXgNCg0KSW50ZWwgQ29ycG9 yYXRp
b24NCkludGVsIEluZGVvriBWaWRlbyA0LjUNCjQuNTEuMTYuMD MNCml
yNDFfMzIuYXgNCkNvcHlyaWdodKkgSW50ZWwgQ29ycG9yYXRpb 24gMT
k5NC0xOTk4DQpJbmRlb64gaXMgYSByZWdpc3RlcmVkIHRyYWRl bWFya
yBvZiBJbnRlbCBDb3Jwb3JhdGlvbg0KaXI0MV8zMi5heA0KNC4 1MS4x
Ni4wMw0KSW50ZWwgSW5kZW+uIFZpZGVvIDQuNQ0KDQo+IEM6XF dJTkR
PV1Ncc3lzdGVtMzJcaXI1MF8zMi5kbGwNCg0KSW50ZWwgQ29yc G9yYX
Rpb24NCkludGVsIEluZGVvriB2aWRlbyA1LjEwDQpSLjUuMTAu MTUuM
i41NQ0KaXI1MF8zMi5kbGwNCkNvcHlyaWdodCCpIDE5OTQtMTk 5OCBJ
bnRlbCBDb3JwLg0KSW5kZW+uIGlzIGEgcmVnaXN0ZXJlZCB0cm FkZW1
hcmsgb2YgSW50ZWwgQ29ycC4NCmlyNTBfMzIuZGxsDQpSLjUuM TAuMT
UuMi41NQ0KSW50ZWwgSW5kZW+uIHZpZGVvIDUuMTANCg0KPiBD OlxXS
U5ET1dTXHN5c3RlbTMyXHdtc3BkbW9kLmRsbA0KPiBDOlxXSU5 ET1dT
XHN5c3RlbTMyXHdtcGFzZi5kbGwNCj4gQzpcV0lORE9XU1xzeX N0ZW0
zMlxNUFIuZGxsDQo+IEM6XFdJTkRPV1Ncc3lzdGVtMzJcZW5jZ GVjLm
RsbA0KDQo2LjUuMjYwMC4yMTgwDQo2LjUuMjYwMC4yMTgwDQoN Cj4gQ
zpcV0lORE9XU1xzeXN0ZW0zMlxhdGlleGR4eC5kbGwNCg0KQVR JIFRl
Y2hub2xvZ2llcyBJbmMuDQpBVEkgVFYgUmF0aW5ncyBNb2R1bG UNCjY
uMTQuMTAuNjIxNw0KYXRpZXhkeHguZGxsDQpDb3B5cmlnaHQgK EMpID
IwMDMgQVRJIFRlY2hub2xvZ2llcyBJbmMuDQphdGlleGR4eC5k bGwNC
jYuMTQuMTAuNjIxNw0KQVRJIFRWIFJhdGluZ3MgTW9kdWxlDQo NCj4g
QzpcV0lORE9XU1xzeXN0ZW0zMlxxZHZkLmRsbA0KDQo2LjUuMj YwMC4
yMTgwDQo2LjUuMjYwMC4yMTgwDQoNCj4gQzpcV0lORE9XU1xze XN0ZW
0zMlx3c3RkZWNvZC5kbGwNCj4gQzpcV0lORE9XU1xzeXN0ZW0z Mlx2Y
mlzdXJmLmF4DQo+IEM6XFdJTkRPV1Ncc3lzdGVtMzJcbXBnMnN wbHQu
YXgNCg0KNi41LjI2MDAuMjE4MA0KNi41LjI2MDAuMjE4MA0KDQ o+IEM
6XFByb2dyYW0gRmlsZXNcQ29tYmluZWQgQ29tbXVuaXR5IENvZ GVjIF
BhY2tcRmlsdGVyc1xXYXZQYWNrRFNTcGxpdHRlci5heA0Kd3d3 Lndhd
nBhY2suY29tDQotDQpXYXZQYWNrIEF1ZGlvIERpcmVjdFNob3c gU3Bs
aXR0ZXINCjEsIDEsIDAsIDMyMw0KV2F2UGFja0RTU3BsaXR0ZX INCkN
vcHlyaWdodCCpIDIwMDUtMjAwNw0KV2F2UGFja0RTU3BsaXR0Z XIuYX
gNCjEsIDEsIDAsIDMyMw0KV2F2UGFjayBBdWRpbyBEaXJlY3RT aG93I
FNwbGl0dGVyDQoNCj4gQzpcUHJvZ3JhbSBGaWxlc1xDb21tb24 gRmls
ZXNcQWhlYWRcRFNGaWx0ZXJcTmVBdWRpby5heA0KDQpOZXJvIE FHDQp
OZXJvIEF1ZGlvIERlY29kZXINCjMsMiwwLDIwYw0KQ29weXJpZ 2h0IC
hDKSAyMDA1IE5lcm8gQUcgYW5kIGl0cyBsaWNlbnNvcnMNCk5l QXVka
W8uYXgNCjEsIDAsIDQsIDY1DQpOZXJvIFN1aXRlDQo=
ERROR #2
Application data:
NKNGIzRkRNUT09DQpJbWFnZUJhc2U6IDAzRDcwMDAwDQpFaXA6 IDRCN
EFBMjANCkVheDogNDc4MDAwMA0KRWN4OiA0NjQ0QTRDDQpFZHg 6IDAN
CkVieDogMA0KRXNpOiA0NjQ0OTk0DQpFZGk6IDQ2MDAwMDANCk VicDo
FNwbGl0dGVyDQoNCj4gQzpcUHJvZ3JhbSBGaWxlc1xDb21iaW5 lZCBD
b21tdW5pdHkgQ29kZWMgUGFja1xGaWx0ZXJzXEZMVlNwbGl0dG VyLmF
4DQpodHRwOi8vc291cmNlZm9yZ2UubmV0L3Byb2plY3RzL21wY y1oYy
8NCkdhYmVzdA0KRkxWIFNwbGl0dGVyDQoxLCAxLCAwLCAwDQpG TFYgU
3BsaXR0ZXINCkNvcHlyaWdodCAoQykgMjAwMi0yMDA5IHNlZSB BVVRI
T1JTIGZpbGUNCkZMVlNwbGl0dGVyLmF4DQoxLCAxLCAwLCAwDQ pGTFY
gU3BsaXR0ZXINCkNDQ1ANCg0KPiBDOlxQcm9ncmFtIEZpbGVzX ENvbW
JpbmVkIENvbW11bml0eSBDb2RlYyBQYWNrXEZpbHRlcnNcV2F2 UGFja
0RTRGVjb2Rlci5heA0Kd3d3LndhdnBhY2suY29tDQotDQpXYXZ QYWNr
IEF1ZGlvIERpcmVjdFNob3cgRGVjb2Rlcg0KMSwgMSwgMCwgND g0DQp
XYXZQYWNrRFNEZWNvZGVyDQpDb3B5cmlnaHQgqSAyMDA1LTIwM DcNCl
dhdlBhY2tEU0RlY29kZXIuYXgNCjEsIDEsIDAsIDQ4NA0KV2F2 UGFja
yBBdWRpbyBEaXJlY3RTaG93IERlY29kZXINCg0KPiBDOlxXSU5 ET1dT
XHN5c3RlbTMyXHN0cm1kbGwuZGxsDQo+IEM6XFdJTkRPV1Ncc3 lzdGV
tMzJcVEFQSTMyLmRsbA0KPiBDOlxXSU5ET1dTXHN5c3RlbTMyX HJ0dX
RpbHMuZGxsDQo+IEM6XFByb2dyYW0gRmlsZXNcQ29tbW9uIEZp bGVzX
EFoZWFkXERTRmlsdGVyXE5lVmlkZW8uYXgNCg0KTmVybyBBRw0 KTVBF
Ry0xLzIvNCAmIEFWQyB2aWRlbyBkZWNvZGVyIHcvIER4VkENCj MsMiw
wLDIwYw0KQ29weXJpZ2h0IChjKSAyMDA1IE5lcm8gQUcgYW5kI Gl0cy
BsaWNlbnNvcnMNCk5lVmlkZW8uYXgNCjIsIDAsIDIsIDQ2DQpO ZXJvI
FN1aXRlDQo=
ERROR #3
Application data:
EFBMjANCkVheDogNENEMDAwMA0KRWN4OiA0QkI0QTRDDQpFZHg 6IDAN
CkVieDogMA0KRXNpOiA0QkI0OTk0DQpFZGk6IDRCNzAwMDANCk VicDo
FN1aXRlDQo=
After these three errors I usually x them out and then the quenc starts its deal and everything seems to be working as last time... the first thing I noticed tho is it ran through the time like a mofo but it was only 5 minutes...as I was typing this I double checked it and now the time remaining is more like it (35 mins at the moment the movie is 50 mins) so is this something to not worry about? -
Still havin no luck with this particular mkv, umm... some things I've tried is changing from the auto audio and played with different settings within ac3 to 2.0 or whatnot... nothing seems to be working... Are there just some dl'd files like this that I'll be encountering.. ? I could always dl another version but I'd rather understand the process... I don't know what I'm doing past the automatic settings and I'm wondering if I need to isolate these streams and convert the audio seperately or something to that affect...thanks
Take a screen image of the error box and make a post to the programs author directly showing him the problem: http://sourceforge.net/projects/avstodvd/forums/forum/700796
I deleted the file but have just now put it back on... I'll get those errors and logs posted soon.. I was reading on some other forums that my problem may have something to do with avstodvd not supporting aac 6 ch... most suggestions were to utilize mkvmerge and recreate ac3 and then send through avstodvd... ??? as a side note I was just reading up on my MB (ma785gmt-ud2h) and found out that 6ch HDMI LPCM isn't supported with its IG (radeon 4200)...looks like goin discrete is a better idea..
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
MKV to MP4 encoding_hardsubbing and audio sync problems.
By Alcatraz in forum Newbie / General discussionsReplies: 11Last Post: 16th Mar 2012, 16:34 -
How To Cut MKV Without Audio/Video Sync Problems
By Eva-Unit01 in forum Video ConversionReplies: 12Last Post: 2nd Mar 2011, 09:11 -
Converting MKV to Mpeg2 audio problems
By anfield7 in forum Video ConversionReplies: 1Last Post: 22nd Feb 2010, 08:39 -
WD TV, Audio problems on 1080 mkv files.
By gustav32 in forum Media Center PC / MediaCentersReplies: 0Last Post: 18th May 2009, 14:28
