:x I was fallowing the instructions of this page:http://www.vcdhelp.com/dvdtovcd.htm after I installed all the software and try it to make some movies,wich were okay in quality and sound,,, then,,,,my plextor stop recording,I don't know why but after I removed all the software and change some crap in the regedit menu,finally,,,now I can use my plextor again(recording) I don't know
if someone else is having a similar problems,but my Adaptec Direct cd software was version 3.5 ,clonecd 2.7, and all the software that the page above recommend,,,,maybe my adaptec is old,I don't know,,anyway,I love this www.vcdhelp.com MANIA ji ji,,,,way to go guys!!!!
just I want to write this note for people who has the same software combination then my..
Also would be very nice if vcdhelp.com put this note in the top of the page and not in the way bottom
) In Order for TMPGEnc to recognise D2V files, you MUST have the VFAPI and the DVD2AVI.VFP file located where the TMPGEnc.EXE file is! it will NOT work any other way! It is also sometimes helps to use the Forced Film option in DVD2AVI, but only if you are still unable to open the D2V files with TMPGEnc. (suggsted by msfox)
This note is here,you need to scroll,all the way to the bottom
Rigo.
Results 1 to 1 of 1
Rigo.F
Warning BD+ Mey Not Have Been Removed
By wulf109 in forum Blu-ray RippingReplies: 10Last Post: 7th Feb 2012, 16:04 -
Need Help With An Avast Warning
By hech54 in forum ComputerReplies: 9Last Post: 21st Feb 2010, 03:18 -
Standard TV warning
By djmobius in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 24th Jul 2008, 07:10 -
Warning: implode()
By handyguy in forum FeedbackReplies: 1Last Post: 24th Aug 2007, 13:02
