Results 1 to 25 of 25
  1. I'm editing a bootleg DVD and received this video but so far after dozens of attempts I can't make the video works fine. First it wouldn't play correctly, so I demuxed it and remuxed into MP4 container again. It had the strange artifacts gone, but continued slow. I thought my processor wasn't performing well so I resized it to 864 x 480, but it continued with the slow-motion thing. I also tried to resample the fps to a higher value but also didn't work.
    i thought i could share with you and maybe someone can help me.
    here's the link:
    http://rapidshare.com/files/353025570/HDV_0080.MP4.html
    thanks in advance.
  2. Member luigi2000's Avatar
    Nov 2003
    Asking for help with project material that you define as illegal is, um, oh yeah--stupid.
  3. this is NOT illegal since the band allows their fans to tape or record their concerts.
    More on this here: http://dreamtheaterhub.com/index.php?action=globalAnnouncements;id=3
  4. Can you post an unprocessed sample? It's hard to figure out if you've already done something to it like resize, or deinterlace
    What are you trying to do? Just play it? or do something else?
  5. oh, this is the "unprocessed" one: i received this as it is.
  6. I'd like to try and help out, but there are no download slots at rapidshare... I'll try again later or maybe someone else can download it
    Again, clarify what you are trying to do (play it, edit it, youtube, put it on a dvd etc....)
  7. i'm trying to make it usable to me. i have other ~10 video sources to multi-track into a DVD but as it is i can't work it with sony vegas
    i'm not sure if it's just my PC or in fact the video is faulty.
  8. so you're trying to import it into vegas, and eventually make a DVD ?
    do you have quicktime installed ? vegas sometimes needs it for .mp4
    can you open the file in mediainfo (view=>text) and copy & paste the info back here?
  9. General
    Complete name : C:\Users\user\Desktop\Praha\vasiliv\HDV_0080.MP4
    Format : MPEG-4
    Format profile : JVT
    Codec ID : avc1
    File size : 84.5 MiB
    Duration : 41s 472ms
    Overall bit rate : 17.1 Mbps
    @sec : UNG
    Video
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 41s 200ms
    Bit rate mode : Variable
    Bit rate : 0
    Maximum bit rate : 0
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 3.161
    Original display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Interlaced
    Scan order : Top Field First
    Stream size : 83.6 MiB (99%)
    Title : SAMSUNG AVC
    Language : English
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 48.0 KHz
    Stream size : 648 KiB (1%)
    Title : SAMSUNG AAC
    Language : English
  10. and yes, i have all needed plugins and softwares (i guess :P)
  11. Does it open in vegas?
    Your computer is probably too slow to handle 1080i AVC content.
    I haven't downloaded the video yet, but the "strange" artifacts you were referring to are probably interlacing I'm guessing
    Many people would encode to a digital intermediate like cineform for editing. (e.g. neoscene) , which is easier on the cpu, but takes more HDD space
  12. vegas open it but is slow. what bugs me is that other 1080i AVC files i can open normally...
  13. Try re-wrapping it into a transport stream (.m2ts) with tsmuxer
  14. with tsmuxer it hasn't any lag, but the image appears pixelated. i'm gonna try neoscene now.
  15. well, i tryed different solutions trought the week but none worked. has anybody downloaded the file and saw if it run ok?
    thanks
    Jan 2009
    Downloaded the file. Not sure exactly what was wrong, but it seems to be fixed by remuxing. I demuxed as raw streams with mp4box and then remuxed with mp4creator with optimize.
    Download here. Think it should work for you now.
  17. but does it run smooth in your pc? here it doesn't show most of the frames. i tried to resize it to 720p but it doesn't work. i'm almost giving up...
  18. Nope, the original file is fine. It 1080i50
    If you are "missing frames" it suggests that your computer is too slow to process it in realtime
    Here is the sample, bob-deinterlaced (so 50p with 2x the frames instead of 25p), resized to SD and encoded with xvid, with the AAC audio copied
    Jan 2009
    That's odd. I couldn't get it to play in MPC-HC (green screen with only sound) and I got basically the same thing trying to open in Virtualdub through ffmpegsource2. Extracting the streams and remuxing allowed it to play fine in MPC-HC. I muxed it at 25fps though, so I must have done it wrong anyways.
    update: yeah, a/v is way out of sync. Should have muxed at 50. Still why would original show green screen while remuxed play clearly? (Original upload is fixed now with 50fps framerate, plays fine now on my machine).
  20. It will depend on your system directshow filter setup to determine whether or not you can play it. For example, I'm using Mainconcept's mp4 splitter. Also Vegas 9's splitter uses Mainconcept's splitter so it works in Vegas too. But, mpchc's internal mp4 splitter doesn't work with interlaced avc in .mp4 container
    Jan 2009
    But it worked fine with a simple remux. It's odd.
  22. Originally Posted by txporter View Post
    Yes, but if you re-read the 1st post, he tried re-wrapping the .mp4 container already, and his primary complaint was "too slow" or missing frames. So that suggests that his system is too slow to keep up. He even says it works fine in vegas but is "too slow"
    Some splitters will give you pixellation with the original file (e.g. VLC's non direct show splitter seems to) , but some splitters work fine with the original file. So it really depends on what filters you have setup if you are using directshow to decode
  23. Originally Posted by poisondeathray View Post
    this worked absolutely perfect in my pc... well, maybe not perfect because the image seems somewhat speedy but it is what i wanted. did you use avisynth?
    how can i copy the settings?
    thanks!
  24. the image seems somewhat speedy but it is what i wanted
    speedy?
    Well you could single rate deinterlace to 25p , but that throws out half the frames (more choppy playback, not from slow CPU, but because it's 1/2 the frame rate an 1/2 the frames). I included an example below
    Yes you can use avisynth to convert to something else for vegas
    You should be able to convert to 720p50 and encode with UT Video Codec (set up the options for faster decoding and threads match your CPU), and you should be able to edit it in vegas (dual might be a bit too slow, you might need a quad core)
    This example of code below would be for 720p50, the audio is included in the script, so I would encode to wave for import into vegas. If you wanted 720p25, change to mode=0. If you wanted another dimension, just change the LancosResize line. If you want , you can use a higher quality deinterlacer (I used yadif because it's faster, mediocre quality)
    Load_Stdcall_Plugin("PATH\yadif.dll")
    FFMpegSource2("HDV_0080.MP4",atrack=-1)
    Yadif(mode=1,order=1)
    LanczosResize(1280,720)
    Cheers
  25. Originally Posted by txporter View Post
    I'm not sure. There are slight differences between .mp4 containers and how splitter handle them. For example using mp4box's default settings will give you different results than mp4muxer. mp4muxer seems to create files more compatible with Quicktime.
    .mp4 container is problematic for interlaced AVC IMO, the majority of splitters and software have issues with it
