I am considering resizing my 1080i captures to 1280x720 to save space.
Two questions:
1) is there a good way to estimate/measure what I will be losing by resizing? My main TV is a Samsung HL-S5087W. I assume that whatever I feed it will be upscaled to 1080p. So I guess I will now effectively being going 1080i-->720p-->1080p.
2) If I decide to go ahead with resize to 1280x720, when should I resize in my avisynth script? This is what I was planning:
Code:MPEG2Source("test.d2v",cpu=3) TFM().TDecimate() Undot() Bicubicresize(1280, 720)
No good way because there are too many variables involved. e.g. quality of player or tv upscaling algorithm, encoding settings, bitrate used, source quality etc. etc...
You have to go through the process from start to finish and play it to be sure
If it was a TV cap, chances are it doesn't have that much detail to warrant 1080p -
you can't do a straight resize before tivtc , fields will get mucked up . It's similar as trying to do interlaced resize. It has to be an interlace aware method
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 05:37 -
1366x768 vs 1280x720
By therock003 in forum Newbie / General discussionsReplies: 3Last Post: 26th Jun 2010, 08:17 -
NTSC HDTV is usually broadcast at 23.976fps, yes?
By Gew in forum Newbie / General discussionsReplies: 38Last Post: 21st Feb 2010, 18:56 -
Issues converting ATSC HD (1080i) broadcast recording to H.264
By alex750 in forum Newbie / General discussionsReplies: 6Last Post: 14th May 2008, 09:03 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / IPTVReplies: 27Last Post: 13th Jul 2007, 16:25
