went to bed turned of my laptop woke up got to school and tried turning the laptop on but it turns on and only shows the first screen witch says Toshiba nothing else. cant get to the bios menu. checked hard drive put a new one in and that one does not turn on either. its like its frozen or something any suggestions how to fix this? I got a Toshiba satellite L350D-S5930
We don't stop playing because we grow old; we grow old because we stop playing.” (George Bernard Shaw, 1856-1950)
i've seen bad ram stop a laptop from booting. take out one stick and try it. then switch with the other if it doesn't work.
RAM is where I'd start also. That would keep you from the BIOS.
Otherwise, you may have a bad motherboard or CPU.
If I remember the machine (desktop), the last one that I had that had a bad CPU could get to the BIOS.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Usually hitting ESC or TAB closes the logo screen and shows the post test results, might be helpful to see what's there.
Perhaps push the hard reset button - usually accomplished by paper clip thru a hole in the bottom (or remove all power including the battery and wait a while).
Andrew Jackson: "It's a poor mind that can only think of one way to spell a word." -
now my screen wont turn on i can tell the laptop fan working but screen wont turn on any suggestions?
We don't stop playing because we grow old; we grow old because we stop playing.” (George Bernard Shaw, 1856-1950) -
First, what did you do? Any additional changes?
Second, try plugging in an external monitor. Check for a keyboard switch to activate.
Third, check to see if you have an extended warranty.
BD Rebuilder failure
By pepegot1 in forum Blu-ray RippingReplies: 5Last Post: 18th Dec 2011, 13:25 -
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 10:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2008, 00:56
