  1. Hi,
    I have done this with ffmpegX several times with the VOB from a DVD. Nevertheless in two of them, it encodes in a matter of seconds and as a result I get a 0Kb.
    The log says
    Encoding started on Fri Feb 19 20:48:56 CET 2010
    Input #0, mpeg, from '/Users/Cris/Desktop/VIDEO CRIS/VTS_01_3.VOB':
    Duration: 00:24:02.8, start: 2881.282033, bitrate: 5952 kb/s
    Stream #0.0: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
    Stream #0.1: Video: mpeg2video, 720x576, 25.00 fps
    Codec type mismatch for mapping #0.0 -> #0.0
    What does it mean? I am lost.
    on thing that seems odd at first is the .VOB contains PCM audio instead of DD,DTS,MPG2 Audio.
    Oct 2005
    666th portal
    i think that usually the first stream is the video. it might not be expecting the audio as #0.0 check some that worked.
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Try setting "Invert mapping" in the Audio tab.
    PCM audio is valid for DVD, and it is also the audio format that e.g. iDVD will create for DVDs. Perhaps because it doesn't require a license from Dolby.
    PCM audio is also sometimes used for its high quality, as it is not compressed.
  5. [QUOTE=Case;1961637]
    It works! Thank you very much case
