    Jul 2005
    great britain
    Hi there, I've been using mkv2vob to play 720p mkv's on my ps3. They play fine.
    However, blacks (mostly blacks, but other colors too) are being washed out. Which gives the output a noticeable quality loss, grainy looking.
    I never transcode the video.
    [Settings used]
    Output Type: File
    Video Transcoding: None
    File Splitting: None
    Output File Extension: Automatic
    Transcoding Codec: x264 High Bitrate (Slow)
    Look at the black difference!!!
    I don't suppose there is another way to play MKV's on a PS3 without quality loss? Or a fix for mkv2vob's black problem.
    Sad really, as I didn't notice it at first and thought this is a great little app, but the washed out blacks are disheartening. And I demand the best !!! lol
    Cheers
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Probably a 0-255 vs. 16-235 luminance scaling issue.
    http://www.kiva.org/about
    My TV has black level adjustments.
    Jul 2005
    great britain
    Actually tell a lie...
    On the PC the black's are washed out (as in the picture above)
    But on PS3 the blacks are blacker than black!!! (not washed out)
    Soo its all good
  5. Member edDV's Avatar
    Mar 2004
    no, not good.
    black should be black in all apps and platforms.
  6. Likely a configuration/playback issue on your PC. What software are you using for playback?
    You're probably using VMR9 or 7(renderless) for the renderer which is common cause of the washed out look . You can change it to something else like video overlay (then adjust in graphics card settings) , or EVR, Haali renderer etc... this will be a big change in how it appears
