How Do I break the lines automatically on the timing list.... from a excel document to a txt or a srt file?
Or... Which program can I use to import xls. files to break the lines to fit better in the frame and time...
I have 6 different languages, each one in a diferent excel sheet, all the lines and time are matching... if I do change the lines in one document, how Can I automatically change in the other languages???
Thanks,,,
I would suggest aggregating all your subtitles into one worksheet; i.e. language 1 in column A, language 2 in column B etc. then place the timings in the next available column. Changing the timing will then affect all languages.
To output subs in srt format is not totally straightforward, but I had a little play and came up with this workaround:
- copy and paste your worksheet into a Word document
- cut out all languages except the one you want
- insert a blank column to the right of the timings
- select the entire table
- choose Table->Convert->Table to Text...
- separate cells with paragraph marks
- now save your document as a plain text file and rename it to .srt
Slainte
midders
P.S. if this is something that you do a lot then you should look into writing a vba script to do the export for you, or consider using Access (or other database) with a custom export script.Last edited by midders; 19th Feb 2010 at 14:52. Reason: P.S.
Volunteer for https://www.computersforkids.org.uk/
Subtitles (.srt) are always slightly off although the timing is correct.
By Crodol in forum SubtitleReplies: 3Last Post: 8th Jan 2010, 01:18 -
subtitles timing
By teamo1976 in forum SubtitleReplies: 3Last Post: 21st Dec 2009, 16:58 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 01:46 -
.SRT to .AVI timing issue
By CLP31 in forum SubtitleReplies: 1Last Post: 19th Jun 2009, 03:04 -
subtitle timing when converted from srt to .sub (for DVD authoring)
By qknet in forum SubtitleReplies: 4Last Post: 10th Oct 2008, 05:22
