Quick question. I have a PAL file and I want to convert it to NTSC. I know how to convert it with Tmpgenc but I was wondering if there is a better way to do it for this situation.
I have a PAL file with black bars on the top and bottom of the movies which is centered. The movie quality is perfect and I don't wand to re-encode it. Is there away for me to cut out the top and bottom black bars without doing intensive re-encoding? The way I am thinking of doing it is to use bbmpeg's "crop frame" function to select a 480x480 crop, then choose: convert to output resolution by "crop".
Anybody know of a easier way to remove the black bars without doing much encoding are reducing the quality of movie? Any suggestion will be truly appreciated.
-rdad
you also need to change the framerate...which requires reencoding.
Oh yeah, i forgot about that. I guess i will go ahead and use bbmpeg. Anybody know if bbmpeg is a decent encoder? Is it close to tmpgenc in quality?
-rdad
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
