I do not know how to do that. Is that tiny script I posted wrong? because as long I can use that script to render out a lossless AVI and all the problems with the source are gone, I more or less know what to do from here on. Thanks, guys.
This will be the first time I have used ffdshow, excluding applications with GUIs that might happen to use it.
Results 61 to 63 of 63
Anonymous344Guest
Anonymous344Guest
The decoder pane shows ffmpeg-dt, so it seems to be set already. Thanks!
Despite reinstalling Avisynth a number of times, I always have to load plugins, whether they are in Avisynth's plugins folder or not. It is irritating, but it is a minor inconvenience really. Thanks again!
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 06:37 -
Playing 480i
By sphinx99 in forum Software PlayingReplies: 1Last Post: 19th Mar 2010, 22:58 -
Using AVCHD (1080i) instead of regular AVI-DV (480i) MINI-DV - argh!
By eddie24 in forum Video ConversionReplies: 4Last Post: 6th Oct 2008, 20:32 -
Is it playing 480i or 1080i???
By elmertborts in forum DVD & Blu-ray PlayersReplies: 3Last Post: 22nd Jan 2008, 14:25 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / IPTVReplies: 27Last Post: 13th Jul 2007, 17:25
