We are using win xp sp3 and are unable to boot up because a file in system32 is mispelled. we can't get to the file because windows is using the ntfs file system. Is there any way to get to the file using some external method?
If you have a floppy drive you can use a boot disk and access the hdd using dos and rename the file.
A Linux or Mac OSX computer can read an NTFS file as can any Windows XP or later machine.
http://www.kiva.org/about -
For a boot floppy to work, you would need an NTFS reader. A Windows or Linux live Cd would work.
However, filenames for Windows System files just do not get misspelled. Either some human deliberately altered the filename, or you have a virus which needs removing.
Any software to rename file based on video properties? good question!
By thomseye in forum Newbie / General discussionsReplies: 10Last Post: 18th Oct 2012, 17:07 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
need file rename tool
By sigpop in forum Video ConversionReplies: 2Last Post: 11th Feb 2011, 20:28 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27 -
USB HD - EX2 or NTFS support with large file
By Robcio in forum DVD & Blu-ray PlayersReplies: 5Last Post: 5th Feb 2008, 10:23
