Look for DVD player that can change from region 1 to all regions
I look to buy a regular DVD player that sale in US for region 1 and can convert to all regions for sure and price about $50. need some suggestion about what brand and model to fit with budget.
Thanks in advance
You also need a player that can convert from PAL format video to America's NTSC format video.
A simple region change(called a region HACK by most) is only half of the battle. -
In that price range, your best bet would be the Philips 5990. It is easily hacked and will play NTSC and PAL. It usually sells for $50 to $60.
wish I had $1 for every time this old chestnut has come up, do a google search for region free dvd players, samstores sell them as well, and the pioneer 420 model can be hacked region free, most if not all dvd players that are or can be hacked region free do pal to ntsc conversion.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
I have a Grundig player that is hackable/hacked but does not do a true conversion....but I'm in Europe so it doesn't matter much.
Change of Region Code incorrectly set on DVD player
By cashey007 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 12th Mar 2010, 22:12 -
how to change DVD player region code on Toshiba SDk 730
By sashatheman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Dec 2009, 07:17 -
Change region on Jensen MP 5000 DVD player
By Lacage in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Mar 2009, 12:31 -
Sony dvp-fx811 portable dvd player region change
By jcgazque in forum Portable VideoReplies: 0Last Post: 2nd Jul 2008, 15:35 -
How to change regions on a DVD or TV?
By SnowStormWolf in forum ProgrammingReplies: 1Last Post: 8th Jul 2007, 18:11
