Hi Everyone,
Sure hope someone can help me. My computer for some reason will not recognize my Pioneer DVR 111L burner. I have been using this thing for years on this computer with no problem until today. After running Google and going to the Pioneer websiteI could not find a legitimate download for this driver anywhere. Can anyone please tell me where I might find it? Otherwise your recommendations for a new burner would be greatly appreciated. I use it mainly to make backup copies for the kids so as not to ruin my expensive originals. Thank you so much for your help.
	Thank You,
 GolfNut
	Have you checked the device manager in windows? Is it listed there? If it's listed you can try uninstall and then reboot and see if windows finds it again.
	You could try here http://tdb.rpc1.org/
	there is no driver for cd/dvd drives. windows has a generic one it uses. if you have been installing/un-installing burning software it's possible that there is left over crud in your registry. search online for "remove upper and lower filters". follow the m.s. instructions and reboot. the drive should show back up. --
	Many thanks to those of you who responded in trying to help me. I got it fixed by doing the below. I hope this will help someone else in the future who may have the same problem. Have a great evening guys.
 1) Go to Start, Run
 2) Type in "regedit" without the quotation marks
 3) Then click on SYSTEM
 4) Then click on CURRENT CONTROL SET
 5) Then click on CONTROL
 6) Then click on CLASS
 7) Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
 8) Then delete the upper and lower filters
 9) Reboot your computer and "wahlah" your drive is now back
 GolfnutThank You,
 GolfNut
  Help with Pioneer DVD Writer DVR-112D and NeroBy tdoran70 in forum DVD & Blu-ray WritersReplies: 6Last Post: 1st Sep 2008, 17:23
  Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognizedBy Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02
  DVD writer exchange for my Pioneer DVR-530HBy J.J.F in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 10:40
  Pioneer dvd-rw dvr-112D Driver UpdateBy scustalow in forum DVD RippingReplies: 1Last Post: 27th Jul 2007, 14:16
  Pioneer 111L only writing at 1.9x speed don't why. Please HelpBy bnbhoha in forum DVD & Blu-ray WritersReplies: 9Last Post: 26th Jun 2007, 11:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
			 ("Success!")
 ("Success!")
