You know how Vegas typically displays frames from the video on the timeline within the track itself so you can visually see what's happening at any given point? Well, since I'm often dealing with clips of up to 15 minutes, it often only displays three frames for the entire project (near the beginning, middle, and end), and if I zoom in on the timeline, it often shows nothing at all.
Is there anyway I can increase the amount of frames displayed on the timeline?
The display of frames on the Vegas timeline is scaled to match the level of zoom. If you zoom out, you get fewer frames, if you zoom in, you see a lot more. You can zoom down to where you see every frame on the time line, and you can zoom beyond this to a point where you may see a lot of empty space around the frames. This is useful for timing audio cuts and mixing, but not much good for video as you cannot cut on less than a frame. If you are getting down to this point then you have zoomed too far. I use the mouse wheel to zoom in steps to the level I need at the time.
Read my blog here.
Thanks Guns1inger--I don't think I'm zooming in that far though. I mean, I can zoom in enough so that there are no images on the timeline, but it covers a 3 minute span, which is quite a bit. So there's no way around that?
Sony Vegas: Timeline Cropping
By mltwitz in forum EditingReplies: 9Last Post: 29th Aug 2009, 05:16 -
Vegas timeline strangeness (screenshot)
By sdsumike619 in forum Newbie / General discussionsReplies: 6Last Post: 28th Oct 2008, 00:49 -
Timeline in Vegas 8?
By guzzi in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2008, 19:48 -
Searching specific frames in VEGAS timeline
By schematic2 in forum EditingReplies: 5Last Post: 21st Apr 2008, 07:52 -
Where is the Video event(/Track) FX timeline in Vegas 7.0?
By mobobo in forum EditingReplies: 5Last Post: 31st May 2007, 04:33
