Hi
Looking to buy a Blu Ray player. Currently have a DVD player which can upscale my existing DVD picture to 1080i/p via its HDMI connection.
A couple of questions.
1 . Will buying a Blu Ray player give me better a picture quality on my existing DVD's or will it be the same quality via my DVD player upscaling facility.
2. Does the HDMI lead need to a professional lead or will a budget lead provide near enough the same picture quality. I have heard that buying a £60 lead is not really worth it as you don't notice much.
Results 1 to 11 of 11
You won't know, until you ask
1) Impossible to answer in general terms. It really depends on the specific model. Some yield higher quality / scaling algorithms , some result in lower quality. You have to test the exact model out
2) No difference over normal distances if you mean HDMI cables. Over very long distances, the more expensive cables can give better quality in some circumstances -
Here in the USA I have bought this HDMI cable:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812123144&cm_re=HDMI_cable-_-12-...-144-_-Product
Roughly 4 British pounds in cost and works great. No need to pay for the "professional" type HDMI cables in my opinion. -
Also depends on what your TV's native resolution is.
Pretty pointless upscaling 576 to 1080 then having the TV downscaling to 768 if that's what the native resolution is. -
Generally, the more expensive cables are better but as said above unless your using extra long lengths, they're overkill.
I have a few Philips 5990 upscalers and they are not as good as myPS3 for upscaling DVDs.I'm not a Sony fan, but the PS3 upscales very well.
Tony -
Deciding on buying a Bluray player you have to consider few other things. On new Bluray discs they only put Dolby HD or DTS HD so if your system doesn't have a decoder or your amp doesn't have HDMI you'll be listening to 2 channel with bluray. The other thing dvd upscale now is very important because there are more dvd's around than Bluray. I bought Oppo Bluray player even though I had PS3. PS3 gets too hot and has too much noise when it gets hot. That oppo worth every penny, dvd backups compressed 70 to 80% look near Bluray quality on a 55". It has analog audio out in case the amp doesn't have HDMI.
What BD's only have HD audio output + stereo only legacy audio?
Here's a second vote for the OPPO. True, it's expensive and you can buy a lot of players for less but the quality can not be beat. They have a cheaper model out now, I cannot speak for it but the BDP83 is great plus built in audio decoders.
If you want good high quality HDMI cables (or any other types of cables) might try http://www.monoprice.com/home/index.asp . Got everything you need and then some and the prices are outstanding.
I have four or 5 of these HDMI cables http://www.amazon.co.uk/gp/product/B0017RW94A/ref=oss_product
43 pence eachCHEERS GARRY
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Best Blu-ray Player For SD Upscaling
By buckethead in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Jul 2011, 21:51 -
Looking for a Blu Ray Player that plays Hulu its my first Blu Ray Player
By marionr26 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 7th Dec 2010, 10:56 -
What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 22:04 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15
