I'm new to this forum and I then apologize if my first question is not in the appropriate section.
The question is: I have sono MP4 movies encoded at 100 CQ with Handbrake (on my Mac) in standard definition (720x336, by the way; I decided for this resolution instead of a correct 720x305 2.35:1 standard in order to have smaller horizontal bars at the top and bottom) and I woul like to apply a sort Photoshop's "Unsharp Mask" effect in order to reduce the "softness" I can see on my 16/9 Sharp LCD TV (1366x768) pixels.
Is there any way to achieve such a goal? I cal also work in Winsow environment if necessary.
TIA
majortom
You could try AVIDemux and apply a sharpen filter and re-encode the video. Problem is, this will reduce the quality and with that you may lose any benefit from applying a sharpening filter. Best to redo the original video with the desired settings. But give it a try. There are Windows and Mac versions of this program available.
And welcome to our forums.
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 11:59 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
how to create "thinking" effect(when someones voice plays in head
By bojadada in forum AudioReplies: 3Last Post: 20th Dec 2008, 12:23 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 21:55
